Thread: Audible spark knock
10-18-2007, 08:02 AM #1
- Oct 2007
- Pittsburgh
Pewter- 2000 Corvettte
Audible spark knock
I own a 2000 corvette 6 speed with 20,000 miles. I use only 93 octane fuel from Sunoco. I had a problem last year with an audible spark knock as GM classified it. I took it into the dealer and they performed the remedy from a bulletin GM had published. The problem came back again this year. It happens in 2nd gear through 6th gear on acceleration. I have contacted GM again and they want me to bring my car back to a dealer and have it diagnosed. They said they would work with me to remedy the problem.
My question is has anyone experienced this and found a different remedy. Forget about any additives, they don't work.
Thanks
10-18-2007, 11:56 AM #2
- Jan 2007
- Mayberry....(Indiana)
Black- 2004 GTO
'04 gto M6 slp ceramic coated headers,B&m sport shifter,harrop cover,3.5"aluminum BMR driveshaft, BMR axle stubs, BMR Half shafts, BMR SFC's, loudmouth2 exaust,90mm FAST T/B,Magancharger(high helix upgrade)......other misc. suspension,Cross drilled, slotted rotors. Meth Kit, spraying @ 3psi and up
04-01-2008, 09:14 PM #3
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
did you ever figure this out? Im having the same issue.
04-02-2008, 03:19 AM #4
- Oct 2007
- Pittsburgh
audible spark knock
I have not figured out the problem. I took my car to the Chevy dealer last fall and they could not find anything out and the car did not make the pinging noise when I went for a drive with the mechanic.
I was talking with my brother the other day and he mentioned to try a "cooler" spark plug within the range that the spec calls for. I am going to change the plugs and find out. If that doesn't work, the next step is to find a reputable speed shop and see if they can identify the problem.
If you find out something different, I would appreciat a heads up.
Thanks and good luck
04-03-2008, 03:33 PM #5
- Dec 2005
I just had my car tuned yesterday and the ping is gone but he had to retard the hell out of it so it borders on sluggish when in mid throttle acc. So that didnt fix the problem just masks it. Im putting in colder plugs and just put a 160 stat in it so those will help. I keep thinking vaccume problem though.
1998 WS6 - Spark Knock Won't Go Away
By 88MonteSS98WS6 in forum General HelpReplies: 16Last Post: 07-12-2014, 02:48 AM -
Knock sensor code and spark plugs....
By Spikito in forum External EngineReplies: 10Last Post: 03-30-2013, 02:09 PM -
Spark knock normal?
By jag42420 in forum General HelpReplies: 5Last Post: 10-16-2006, 04:10 AM -
Spark Knock
By DSkyles in forum General HelpReplies: 5Last Post: 01-25-2006, 07:55 PM -
Spark knock help
By 02 super sport in forum General HelpReplies: 7Last Post: 12-24-2005, 06:09 PM
