Results 1 to 3 of 3
    texas
    2002 ss camaro
    engine noise on radio
    the battery is dead on my 02 ss (the car has 8007 miles). i jumped it off and i'm getting engine interference over the radio. seems to me i remember an old z71 truck of mine doing that and it was the altenator. i cleaned the terminals on the battery they were not too bad. also the battery will not take a charge from my battery charger. could the side mounted battery end be corroded were i cant see? like internaly. will a bad battery also do the radio noise thing. i live 20 miles from the chain auto stores that test for free so any help will be appreciated.
    Take the battery to a parts store and have it tested....it's free. Typically on all the batteries I've dealt with if they won't take a charge from a charger they're shot. I will cut back a little bit of insulation on cables sometimes to see if the corrosion runs back under the insulator. I tape it back up when I'm done. Probably stuff you already knew but sometimes the little things is what gets you.
    www.eautocad.com
    FL
    1998 Camaro Z28
    id say its the alernator, or your ground wire for the radio has some corrosion.. maybe a bad battery as well... Try running a new ground for your radio by itself, rather than the ground for the harness.
  1. Help: What could this engine noise be???
    By James Reid in forum General Help
    Last Post: 07-25-2016, 04:09 PM
  2. After I fix my engine noise, what next?
    By Naaman in forum General Help
    Last Post: 09-14-2013, 01:02 AM
  3. Engine noise
    By JayTA98 in forum General Help
    Last Post: 06-29-2009, 07:18 AM
  4. Engine noise help
    By seasponge in forum General Help
    Last Post: 07-01-2007, 11:47 AM
  5. Radio static noise
    By '96 collector's in forum New Member Introductions
    Last Post: 06-23-2007, 06:03 AM
