    osage beach mo
    please help with fuel problem
    I have two intake 255 walbro fuel pumps, wired together inside the tank inside the stock boot, then wired to the factory plug ins on top of the fuel tank, and one wire keeps melting and I loose all power to the fuel pumps is there a peice I can buy to keep this from happening or a better way to hook them up? thanks
    talk to Matt at Harris Speed Works. Click on "sponsors" at the top of the page and they have a link there. What wire is melting? Hot wire from the plug going up to the top of the tank? What year is your f-body?
    osage beach mo
    the car is a 2002 yes that is the exact wire
    I would assume that 2 pumps is just to much of a current draw for that wire. What gauge is that stuff? ~16-18 gauge? I'm sure you can beef up that harness. Talk to Matt and see what he has to say.
    Feb 2006
    2002 WS6
    If you are running two pumps run two cricuits that way if on pump shorts it wont take the other with it and possiblt leave you standed, plus it will also reduce the over load on the wiring in general becuase you are spliting the draw between two circuits.
    osage beach mo
    Quote Originally Posted by Orcus79 View Post
    thank you that is exactly what I did with 10 gauge wiring,
  1. Possible Fuel Problem??
    By GottaHaveLS1 in forum General Help
    Last Post: 06-15-2008, 03:18 PM
  2. Fuel Problem
    By speedracer25f in forum General Help
    Last Post: 03-05-2008, 01:15 PM
  3. Fuel Problem or Severe Engine Problem
    By pet_monk in forum General Help
    Last Post: 02-18-2008, 07:51 AM
  4. Need Help With Fuel Problem.
    By Street Fighter in forum General Help
    Last Post: 12-12-2006, 03:48 AM
  5. Help with fuel problem!!!!!
    By Corvettejon in forum Camaro / SS
    Last Post: 01-05-2006, 09:57 AM
