Results 1 to 3 of 3
Thread: Sleeves
    Member 346ci's Avatar
    AK
    1998 Z-28
    Sleeves
    Has anybody heard of putting sleeves on the block? I'm just curious as to what is involved/happens when someone puts "sleeves" on their block? I'm assuming it makes the block stronger. Thanks.
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    The LS1 is aluminum so it has sleeves in it already, now if you change the sleeves to a thinner one it would be like boring an Iron block. change the crank and you would have a bored and stroked motor. it would essentially change your C.I. of the motor, depending on what crank and how then sleeves you went with. i.e. 383..402..408..etc
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    They basically bore them out to put the larger ones in. Unless you are talking about the Darton kit which actually carves the whole deck section out and replaces them with their stronger MID interlocking sleeves which replaces the entire deck pretty much.
  1. Metal protective sleeves for spark plug wires?
    By paratrooper in forum External Engine
    Last Post: 10-22-2009, 09:02 AM
  2. Question: Sleeves for CAI
    By The Silver Goat in forum GTO
    Last Post: 01-17-2009, 04:00 AM
  3. Can you replace the sleeves to overbore...?
    By theTANTALIZINGSS in forum Camaro / SS
    Last Post: 08-18-2005, 03:36 PM
