Results 1 to 20 of 21
Thread: Sleeves for CAI
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    Sleeves for CAI
    I've had a K & N CAI on Bessy for 2 years and the OEM sleeves are degrading and leaking. I've adjusted my slope injection without making other changes and continue to get lean codes so I know I've got leak somewhere. I've taken the system apart and put it back together numerous times...
    So, I've seen pic's of blue sleeves on various motors and want to buy them. They appear thicker and made better.
    Who sells them?
    I'm $hit green bricks if somebody sez home depot / lowes
    2 badass birds
    OK
    RED/black
    97ws6/05 GTO
    it sounds like you have something else going on possibly. Those couplers should last a lot longer than that. Are you certain that ones leaking? What kind of tune are you using? Since you say you changed your slope can I assume you're using a diablo predator? You can check for vacuum leaks by going around everything with propane and listening for the idle to change.
    2 badass birds
    OK
    RED/black
    97ws6/05 GTO
    yeah those intakes can leak at the hot seam double check and epoxy it if needed.
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    has the intake ever been off the car? id start there check at the rear of the intake, maybe one of the lines are off do the brakes work as normal?
    typically if you're getting unmetered air in there it'll show up in the idle also.
    Dearborn Michigan
    2004 GTO - M6
    it sounds like you have something else going on possibly. Those couplers should last a lot longer than that. Are you certain that ones leaking? Best I can Tell
    What kind of tune are you using? Dyno tune on a Diablo
    Since you say you changed your slope can I assume you're using a diablo predator? See above
    How do you you use propane to look for leaks - are you saying with a flame?
    Dearborn Michigan
    2004 GTO - M6
    Quote Originally Posted by qwkgto View Post
    No - I've never taken the intake off.
    Brakes work fine, but I'll check around the entire engine...
    2005 GTO
    Quote Originally Posted by The Silver Goat View Post
    you use the propane as a gas not a flame to check for leaks the car will rev up if you have a vaccume leak ,get a propane torch dont lite it,just use gas to find leak.
    2 badass birds
    OK
    RED/black
    97ws6/05 GTO
    or water in a fine sprayer like most cleaners come in spray around the intake engine will suck in water and stumble a bit ( if you don't have propane or mapgas around or are afraid of a fire)
    tb/ to intake seal, all around bolts, injectors, sealing edges.
    footbrake racer racer426's Avatar
    Jan 2008
    antioch,tn
    2004 gto
    use brake cleaner or ether to find vacuum leaks.alot safer than propane
    Quote Originally Posted by racer426 View Post
    I use propane because it doesn't require you to spray the engine down with anything....haven't been blow up yet.
    2005 GTO
    thats what she said 2..lol
    2005 GTO
    any updates what did you find?
    Dearborn Michigan
    2004 GTO - M6
    A week before x-mas a pipe broke in the condo above my inlaws, so been busy with that. Foreclosure
    I covered over x-mas break... I work in Facilities Management
    Now we've got about 9 inches of snow and it's going down to -30...tonight
    She's been tucked away since the middle of november.
    Questions were prep'ing for spring time.
    no flame....I just use a propane torch unlit and go around the lines with the gas.
    also, does the car run any different? What mods do you have done to it?
    Dearborn Michigan
    2004 GTO - M6
    160 tstat
    K & N CIA
    Dynojet tune
    Borla dual exhaust
    CAGS Eliminated
    PCV Delete / a PFYC breather
    Oil Catch Can
    NGK plugs
    Bessie runs fine - I'll run her to the north country here during summer and get 27 to 28 mpg running along at 80-85. We have a boat load of bubble tops waiting to pick you off. As soon as I get off e-way and start across the state I'm up to 29-30 running along at 60-65. My father lives up north on a bay here...
    So mpg is good, no other issues, just a lean code over time if I use the custom tune. The initial setting on the is -10% & a 12.5/1 AFR. To balance the LTF's I have to move her to -16% to get those to hover around 0%. Seems a little high to me from everything I've read.
    I obtain the mpg with either setting...
    have you looked at your ltft's with the diablo? Any certain place where they go positive? Sounds like your tune just needs some work. Might be time to invest in hptuners.
    2005 GTO
    +1 those hand helds are very limited to a tuners point,HP can change things you never dreamed of...
  1. Metal protective sleeves for spark plug wires?
    By paratrooper in forum External Engine
    Last Post: 10-22-2009, 09:02 AM
  2. Sleeves
    By 346ci in forum Internal Engine
    Last Post: 10-05-2007, 09:23 AM
  3. Can you replace the sleeves to overbore...?
    By theTANTALIZINGSS in forum Camaro / SS
    Last Post: 08-18-2005, 03:36 PM
