Results 1 to 3 of 3
    Slow SS
    P-Cola
    2002 Chevy Camaro
    VATS or clutch switch
    Ok, 2002 Camaro SS M6
    occasionally it will not start when key is turned. I generally stomp on the clutch a few times, then try it, then wiggle the key and try it, then stomp on the clutch and wiggle the key and try it, curse, then try some other combination of the aformentioned processes and it will start. The battery and alturnator are fine. The car has 106k on the clock. It seems to be unrelated to temperature or anything else, almost entirely random. The lights and radio still come on with the key turned which makes me lean toward a clutch switch.
    my key is slightly worn, but I don't consider it excessive. Is there a way to check either problem out to verify if it is the cause without too much trouble?
    Dave
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    If your lights and radio still come one I would go with clutch switch. When I had an issue with my vats nothing worked period all I got was the security light would come on and nothing else would happen. No lights no clicking like a dead bat nothing at all just the security light would come on for 2min then go out then I could try to start it again.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    is the security light on? If no then it's not VATS.
  1. Help: 98 camaro vats problems and clutch/trans
    By pk222 in forum V6
    Last Post: 08-11-2011, 08:32 AM
  2. Question: Engine won't crank, not VATS, clutch safety switch, battery
    By 318Charger in forum General Help
    Last Post: 09-09-2010, 04:03 PM
  3. Help: Clutch switch issues
    By BADHAWK209 in forum Manual Transmission
    Last Post: 07-07-2010, 04:07 PM
  4. VATS or Clutch Switch
    By dlbrando in forum Camaro / SS
    Last Post: 10-04-2007, 06:30 PM
  5. Clutch Switch?
    By chrishuckeba in forum Manual Transmission
    Last Post: 09-22-2005, 06:52 AM
