Results 1 to 18 of 18
    Junior Member BADHAWK209's Avatar
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    Clutch switch issues
    I have a 2000 TA with M6 MY CHECK ENGINE LIGHT CAME ON ONE DAY,SO I PLUG IN THE OBD 2 SCANNER.AND ITS THROWING CODE PO 704 FOR THE CLUTCH SWITCH.I WAS ABLE TO START THE CAR WITHOUT DEPRESSING THE CLUTCH UNTIL I REPLACED THE SWITCH WITH A NEW ONE.OK SO I ERASED THE CODE. A WEEK LATER THE SES LIGHT APPEARS AGAIN WITH THE SAME CODE AFTER I PUT THE NEW SWITCH IN. ITS ALSO AFFECTING MY CRIUSE CONTROL ANY ONE KNOW GOING ON HERE??
    Indianapolis
    2000 WS6 6spd Hooker LT
    Can you still start the car without depressing the clutch pedal? If so, could be a bad new switch or wiring to it. I've never heard of anybody with this issue. Does you scanner just show codes, or can you see the data? That would help, it would show the clutch switch position.
    And yes, it affects cruise, if the PCM thinks the pedal is touched in the slightest, it disables cruise.
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    NO i have to depress the pedal the scanner only shows codes.I looked in the manule that came with the scanner.IT SAYS (CODE PO704 CLUTCH SWITCH INPUT CIRCUIT MALFUNCTION).
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    That code is for the Clutch anticipate Switch. It is depressed (and electrical open) when you have the clutch pedal released. it is adjustable so maybe it needs to be pushed back into it bracket.
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    I have it on the bracket its lined up with the pedal.
    Madison, WI
    2001 Silverado Z71
    Where did you get the clutch switch from when you replaced it the first time? maybe its a cheap shitty switch that didn't last too long?
    Do you have a meter you can test the switch with?
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    Its the same switch that comes stock on the car, I got it new from Auto zone it cost about 5 bucks. I think i do have one of those volt meters you were talking about.
    Madison, WI
    2001 Silverado Z71
    Quote Originally Posted by BADHAWK209 View Post
    ChinaZone electronics...that could be your problem.
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I replace my clutch master cyl with a tick proformence adjustable master and I have the same code my cruise also isn't working
    Madison, WI
    2001 Silverado Z71
    Quote Originally Posted by 2000dreambird View Post
    In your case, I bet the pedal isn't coming all the way back to push on the switch plunger.
    Indianapolis
    If your switch checks ok, then it is an electrical issue going to the switch. Does it connect to the connector ok?
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    I just checked it to see if it was connected properly its on there good. I still have to check the switch circuit though.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    Now if I adjust the pedal higher to hit the switch is it possible to overthrow the clutch an damage something ?
    Indianapolis
    ^^^Why not adjust the switch to contact the pedal, it's adjustable that way. Unless you've modded it somehow.
    The best way to check the switch would be with it connected and see if it switches while depressing the clutch. Should not take much movement to see the voltage change. I don't have a wiring diagram, but just in case you should used a DVOM, not an old-school needle type, to protect electronics. These things are wired into processors.
    Arizona
    Exactly. The switch does have adjustment to it. I've had to adjust ours. I still had to depress the clutch to start the car but the cruise control wasn't working. The pedal just wasn't contacting the switch enough I guess.
    After I adjusted the switch some more, the cruise has worked perfectly.
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    I do have o depress to start but the cruise dosnt work. I didn't know the switch was adjustable I'll take a look at it but it's like 105 outside right now so it will have to wait
    Jun 2010
    Stockton,CA
    BLACK
    00 TRANS AM M6
    Yea i just replaced one awhile ago and the service engine light came back on and no cruise at all
    Indianapolis
    105? That's nothing. It was 92 in the shade of the shop this afternoon.
  1. CLUTCH issues..
    By foxman92 in forum Manual Transmission
    Last Post: 07-19-2009, 10:40 AM
  2. VATS or Clutch Switch
    By dlbrando in forum Camaro / SS
    Last Post: 10-04-2007, 06:30 PM
  3. VATS or clutch switch
    By dlbrando in forum General Help
    Last Post: 10-04-2007, 05:10 PM
  4. clutch safety switch
    By turbols1chick in forum Firebird / WS6
    Last Post: 12-26-2006, 04:39 AM
  5. Clutch Switch?
    By chrishuckeba in forum Manual Transmission
    Last Post: 09-22-2005, 06:52 AM
