Results 1 to 20 of 26
    Member TROYWS6X's Avatar
    New York
    1998 WS6
    Question head light grinding
    My passenger side head light hasn't been coming up every time I turn on the lights, so today I raised it manually to lube it, hoping it wasn't the gear and just the linkage, and the lube would fix it. All the I took apart was the plastic frame around the lights so I could get to the linkage easier. I put it back together and tried it and it works, but there is a loud gringing coming from the motor after it goes down . It lasts for a couple of seconds and stops. Also, when I lock the car, the lights pop up and down. It never did that before. All I did was spray some WD40 on the linkage that raises the head light. Did I somehow mess up the timing by only raising one head light at a time?
    Indianapolis
    Black on black
    2000 Trans Am WS6
    I am having the same problem with the grinding sound from the driver side. I was searching around last night and found a lot of info out there on this topic. I havent had time to work on mine yet but it sounds like the motor has came lose, which happens a lot judging by all the threads out there. As for the light popping up I remember reading some stuff on that while I was looking last night but I didnt pay any attention to it.
    Good luck and if you end up needing a gear they are about $48 shipped for a brass one.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    More than likely it is the gear. If I were you I'd fork the money out and just change it out. I did mine years ago and have never had a problem since!
    Drive it like its stolen gillahoon's Avatar
    Carbondale, Pa
    I trough it was the gear on my and got the new gear and it still did it, what it really is the motor is losse. you have to take it out and hammer the little tabs that hold the metal caseing, so it dont wiggle. when u take it out u will be able to feel it move and it has to be tight.
    New York
    1998 WS6
    Quote Originally Posted by gillahoon View Post
    I'll give it a try before I order the brass gear.
    Thanks
    Junior Member 98_Ws6_scooter's Avatar
    Southwest Va
    1998 Trans am A4 Ws7
    Quote Originally Posted by TROYWS6X View Post
    My 98 is doin the same thing and my driver side headlight motor is making the grinding after it goes down ..... what is the problem with the lights flippin up when locking the car?????
    Thanks
    homer glen il
    1998 bmw z3
    2001 is doing the same thing passenger side. Headlights never went up and down when locking before all of a sudden they do and when it goes down makes that grinding noise. never seen this before.
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Sounds like you need to fix/replace the headlight motor gear...
    Junior Member Airguy's Avatar
    Little Rock
    1999 Trans Am
    So its not suppose to flip up and down when locking doors? Time to fix this problem. So what do I need to replace or fix? The motors need to be replace or gears?
    Thanks again
    Moving forward. Pyromaniacal's Avatar
    Utah
    Blue/Yellow/White
    95 T/A 383
    It absolutely is your headlight motor gear. This very same thing happened to me and when I changed the gear, all was well.
    Here is a link you will find invaluable..
    http://www.bfranker.badz28.com/headlightfix/index.htm
    Now as a friendly warning, this is an easy operation, but it must be carefully undertaken. When you are putting in your brass headlight gear (40$ approx) make sure it is properly put in and sitting well, if you do not, it will only be a matter of time before it starts stripping the brass gear and you're going to be right back where you started.
    Goodluck!
    2-Legit-2-Quit bgable's Avatar
    Cville,Indiana
    IBM
    2006 Pontiac GTO
    i just took out the gear and spun 180 degrees then that side is unstripped fixed mine and this was free and mine was doin the exact same thing yours was
    Member svt_eater's Avatar
    Ontario, Canada
    2002 Firehawk
    SO many people with this problem. My car was less than 2 years old when it happened to me. The dealer said they replaced the passenger side motor, and I then had them replace the driver side one just to make sure it wouldn't be an issue in the near future...they covered both under warranty...I said the driver side one was slower than the new passenger side one and no questions asked.
    Anyway, I had the same lights popping up thing happening when I locked the doors when that happened. I just pulled the fuses for the headlight motors until I had it fixed. It's a painful noise to hear coming from your car, that is for damn sure.
    My problem hasn't come back, but there are more suggestions in this post than I have seen anywhere else, from free fixes, to the brass gears, I think everything is covered here.
    Junior Member 96t/a's Avatar
    texas
    1996 Trans Am
    my passenger side headlight is doing almost the same thing except, whenever i turn my headlights of it pops back up by itself and makes the grinding noise. it pops back up but the lights not on?
    dallas
    mine did the same thing, hit the alarm and headlights would wink at me then grind. i just took the headlight motor out, pulled the output gear out and turned it 180* and put it back in with a little wheel bearing grease. know more winking and grinding.
    Junior Member Jay_dub87's Avatar
    Iowa
    2001 Formula
    my car does the same thing... I have an '01 and the passenger side light has been making that loud noise for a week now. I feel bad coming home late at night and turning the lights off... I feel like I'm waking up the neighbors....
    I found a site that explain how to switch out the gear, looks pretty easy.... but I need to get off my ass one of these days and do it... hmm.
    Indianapolis
    Black on black
    2000 Trans Am WS6
    Angry
    I changed out my drivers side gear and no more grinding. As for that pain in the ass cover that has to come off to get the gear out one stich took care of my hand.
    Ontario, Canada
    2002 Firehawk
    Quote Originally Posted by summy View Post
    Ouch! I try to wear Mechanix gloves as much as I can when working on the car...I'm sure they have saved me a few times now. They aren't always workable though...especially with more intricate parts.
    Drivin It Like I Stole It JWSmythe's Avatar
    Tampa, FL
    '00 TransAm WS/6
    My '98 TA is doing that..
    Well, two different problems. The first one was that it would grind on the way down, just after it closed, and then flip open&closed when I locked the doors.
    You can actually disconnect the arm at the motor, and rotate it 180 degrees, to get onto the "good" side of the gears (like a few other people have suggested). That worked great for a month or two.
    Right now, when it's on it's way *UP*, it gets stuck either on the front bumper and doesn't move at all, or half way up, where I have to run around to the passenger side and lift it so it can catch a good gear. It's only about 1/2" movement, but it'll finish going up and lock in place.
    I already took the drivers side motor apart, so I'm familiar with the guts of it. That gear was badly worn on half the travel, so I rotated it, and it's been fine.
    Really, they're not that bad to take apart. Just make sure you don't take apart the actual motor (like a slightly over-sized D battery). If you do, the brushes -n- stuff will come loose, and you'll wonder why you started doing this. It's not impossible to get back together, just hard enough to annoy you. Be sure to lube the gears if/when you take it all apart. Mine was barely lubed, which probably caused a lot of the wear.
    Southwest Va
    ok update...
    Replaced the headlight motor with a lifetime free replacement motor from autozone for 100 bucks.... totally fixed my light problems.. and fairly easy install...
    Indianapolis
    Black on black
    2000 Trans Am WS6
    Was that for everything (motor and gear unit) or just for the motor?
  1. need help with head light motor
    By Street Fighter in forum General Help
    Last Post: 01-14-2016, 06:01 PM
  2. Tail Light, Head Light Lens Cleanup, Body Work Questions
    By MAXX2 in forum Appearance Section
    Last Post: 12-15-2010, 08:15 AM
  3. Replies: 6
    Last Post: 07-08-2006, 05:06 PM
  4. Head light help
    By LS1WTA in forum General Help
    Last Post: 04-08-2006, 12:41 PM
  5. head light help
    By minorthreat360 in forum General Help
    Last Post: 11-21-2005, 06:39 AM
