Thread: head light help
11-14-2005, 03:12 AM #1minorthreat360Guest
head light help
i have 96 firebird and i cant see crap at night time when its raining.
some times it seems like the head lights arent even on. what is some thing i can do??
11-14-2005, 11:56 PM #2minorthreat360Guest
bump
11-16-2005, 12:54 AM #3Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Do you have headlight covers??? If so take the 2-min when its raining to take them off, if you have fog-lights turn them on, if not get a set. This will help some but not much because since they are so low to the ground they dont reflect that much of the ground back up to you, they instead just bounce off the smooth water covered pavement and keep going straight out. Try installing some brighter bulbs, please dont ask me to recomend some because I run my stock units and they work fine, last thing I would check is the voltage of your charging system. If it only like 12.5 volts when running that could mean a light out-put reduction of like 40% compared to 13.5 or 14.5
Hope this helps.
11-21-2005, 04:42 AM #4minorthreat360Guest
what are head light covers.????
did the 96 bird come with them.???
11-21-2005, 06:39 AM #5
You might can try adjusting your headlights which is really simple and makes a world of difference. Just find a level surface and park your car about six feet away from a 90 degree wall. Flip your headlights on and you can see exactly where they are shining( in your case they are probobly pointed at the ground) and just adjust them to where they are level but not to high. Unless you have a headlight aimer the rest will be trial and error by getting out at night on the interstate and seeing how they need to be adjusted.
need help with head light motor
By Street Fighter in forum General HelpReplies: 6Last Post: 01-14-2016, 06:01 PM -
Tail Light, Head Light Lens Cleanup, Body Work Questions
By MAXX2 in forum Appearance SectionReplies: 3Last Post: 12-15-2010, 08:15 AM -
Need help repairing head light .
By Street Fighter in forum General HelpReplies: 6Last Post: 10-02-2010, 02:23 PM -
head light grinding
By TROYWS6X in forum Firebird / WS6Replies: 25Last Post: 10-25-2007, 12:38 PM -
Head light help
By LS1WTA in forum General HelpReplies: 0Last Post: 04-08-2006, 12:41 PM
