Results 1 to 10 of 10
09-30-2007, 05:02 PM #1
is a nitrous controller necessary?
well i heard that there great. some even running 10's dont use them but some with 12's use them. just want to know if i should get one and if it EVEN WORTH IT.
09-30-2007, 05:02 PM #2
and how hould it progress my 150 shot set up
09-30-2007, 08:59 PM #3
It makes it easy on parts due to the initial hit NOT being so hard. We have a car that goes mid 9's with NO progressive. With street tires or cars that get street raced more than track use they are a must unless you do a baby shot 125 or less.
It all depends on what your purpose is.....They are getting cheaper and cheaper.Don't be afraid of the bottle!!! Be afraid of your tune!!!
09-30-2007, 09:01 PM #4
10-01-2007, 11:27 AM #5
For 150 shot, I run a window switch, but no progressive function. Keep in mind progressive controllers pulse your noids therefore putting them under increased stress.
10-01-2007, 02:01 PM #6
10-02-2007, 03:22 PM #7
10-02-2007, 05:10 PM #8
I don't use the progressive control, but I do have a digiset time looped through the WOT switch. That way I can delay the spray at the launch for better traction ! Here's one on E-Bay now !
http://cgi.ebay.com/ebaymotors/nos-d...spagenameZWDVW
You can adjust in .1 sec increments !!! I usally go .3 on a bad day...
10-02-2007, 07:38 PM #9
thanks alot, you are the spary guro !!
10-03-2007, 08:40 AM #10
The car runs VERY well! I haven't had it to the track yet - and found out when I had it on the dyno (#s below) that the bottle was very low and still turned decent numbers. I think on a full bottle I'd be in the 460-475hp range. As long as your timing is set to stock, you should be fine to go to the 150hp right out of the box.
To be safe, you could get it tuned on the 150 shot to be sure you're not getting any KR or running it lean at all.
GL HTH,
-Eagle| '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
HSW Nitrous controller
By Blue_01_Z28 in forum NitrousReplies: 8Last Post: 04-18-2011, 09:12 AM -
Do I need a nitrous controller?
By jmatt07 in forum NitrousReplies: 3Last Post: 02-24-2009, 07:54 AM -
New MicroEDGE nitrous controller from HSW!
By Matt@HSW in forum NitrousReplies: 15Last Post: 09-19-2008, 10:25 AM -
Nitrous Controller
By whtknt in forum NitrousReplies: 7Last Post: 02-03-2006, 05:45 AM -
New Product!!! Progressive Nitrous Controller
By Matt@HSW in forum NitrousReplies: 11Last Post: 11-12-2005, 08:16 AM
