    South Africa
    Installing a Crank Pulley on LS1
    Hi
    The GM manual suggests that one uses a special tool to install a crank pulley onto an LS1. Unfortunately I do not have such a tool and as I am based in South Africa, obtaining one is not that easy. Hence the question:
    How do I go about intalling a crank pulley on a LS1 without the special tool?
    Any advise/suggestions appreciated
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    If you are alittle creative you could probly make one.
    Junior Member TwiSSter418's Avatar
    Florida mostly
    A friend of mine had this problem the other day. he couldnt get the pulley back on because the crank bolt is too short... I don't know if this is the same problem you're having or not, but I have an ARP crank pulley, which is longer and would solve the problem.
    stole this pic off ls1tech on how to make your own tool:
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    A ARP crank bolt will work to but the original balancer back on, just dont the washer at first and it will go right on.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by TwiSSter418 View Post
    Hmmmm...cool
    I made a tool just like the one pictured. Worked out pretty good. I'll dig up the specs on the thread stock because I forget them right off hand. I *think* it's an M16x2.0 pitch.
    Stroked Slowmaro
    East Tennessee
    2000 Z/28
    Heat it in the oven for about 30 min. Get some gloves and work quick. Put some oil on end of crank. You may have to tap it lightly with a rubber mallet a few times. You'll be surprised how far you can push it on the crank. Pull it on with the old bolt. Crude, but it worked fine for me. Im sure some people on this site will freak out over this.
    EastTNZ28
    South Africa
    Thanks for all the suggestions. With that information I am sure that I should be able to make the necessary tool to do the job.
    Marylandistan
    2001 Trans Am (sold)
    I have one just like the one pictured above. This guy sells the nicest one I have seen to date. http://www.ls1tech.com/forums/showthread.php?t=391883
    Bragg NC
    Met. Sunset Orange
    01 SS
    Quote Originally Posted by EastTNZ28 View Post
    Lol, Now thats creative, But if it worked it worked
    J
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Quote Originally Posted by sunsetorangess View Post
    J
    Thats the way i've always installed balancers or underdrive pulleys.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    I tossed mine in the oven for a few minutes also. I didn't pull it on with the old bolt though. I spent $20 and made a tool to push it on instead. Removes any chance of damaging the crank threads.
  1. Wanted: Oversize 6 rib crank pulley
    By peterurdahl in forum Parts Wanted / Trade
    Last Post: 03-05-2013, 02:45 PM
  2. Can't get crank pulley off? tried using pulley puller
    By JehalinTA in forum Internal Engine
    Last Post: 06-22-2011, 06:06 PM
  3. Installing crank pulley on LS1
    By South Africa in forum External Engine
    Last Post: 09-28-2007, 07:01 AM
  4. installing asp underdrive pulley
    By dag711 in forum External Engine
    Last Post: 09-26-2007, 06:04 PM
  5. MMS Crank Pulley, Reichard Racing Pulley
    By Hodgesz28 in forum Parts For Sale / Trade
    Last Post: 08-18-2006, 08:38 AM
