Results 1 to 16 of 16
Thread: installing asp underdrive pulley
09-24-2007, 02:33 PM #1rique71
- Mar 2006
- tampa fl.
white- 1998 z28
i am wanting to install this myself and i did a search on the install and went to ls1 how to , looks pretty simple. the only thing that has me worried is the part about putting a screwdriver in the flywheel to keep it from moving. what bothers me about doing this myself is , what if i put a screwdriver in the flywheel , and the engine still moves ? will that cause a big problem inside the engine
09-24-2007, 05:33 PM #2
It won't cause any problems if the engine moves. If you have a m6 you can just put the car in gear to keep the motor from turning. Not sure on an a4 other than the old screwdriver in the flywheel.
05 PBM GTO
Cold Air Inductions CAI,Relocated IAT with omega,Slp Predator tune,Flowmaster axle back with H pipe,Custom tuned TCM.BC Racing coil overs
Sold 01 z28
09-24-2007, 05:45 PM #3rique71
- Mar 2006
- tampa fl.
white- 1998 z28
r there any special tools needed for this other than a puller?
09-24-2007, 06:01 PM #4
subscribing
09-24-2007, 07:12 PM #5Just me
- Nov 2006
- Broken Arrow, OK
You may already know, but in case you don't, you need a new crank bolt. The original is a torque to yield and can not be used again. A new one from the dealership will run you about $5-6.
09-24-2007, 08:28 PM #6
09-25-2007, 05:42 AM #7rique71
- Mar 2006
- tampa fl.
white- 1998 z28
ended up taking it to mechanic cause i got called into work and he just told me that the pulley goes in to deep and he cant get the belts on .
09-25-2007, 08:22 AM #8
09-25-2007, 08:32 AM #9rique71
- Mar 2006
- tampa fl.
white- 1998 z28
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=003 this is what i bought
09-25-2007, 05:52 PM #10rique71
- Mar 2006
- tampa fl.
white- 1998 z28
anyone?
09-25-2007, 08:09 PM #11
that looks like the right one. I would get the part number and call somewhere to verify the part number is correct.
09-25-2007, 08:29 PM #12rique71
- Mar 2006
- tampa fl.
white- 1998 z28
i was just looking at the thunder racing website, and if i looked at the right things i think they r to different part numbers
09-25-2007, 10:52 PM #13
Yeah, I just looked at TR too. The part numbers are different. To be honest with you I'm not exactly sure what's different between the two. The vettes accessories are in different spots but I didn't know that would effect the depth of the pulley. Learn something everyday.
09-26-2007, 03:03 PM #14
Looks like the same pulley I got.
09-26-2007, 04:37 PM #15Junior Member
- Jul 2007
- Kingston, Tn
Black- 1970 Convertible Corvette
My ASP Underdrive pulley has part number 948500. It is for a F body LS motor according to LMMotorsports where I bought mine at.
09-26-2007, 06:04 PM #16rique71
- Mar 2006
- tampa fl.
white- 1998 z28
is it stamped on the pulley?
93-97 lt1 bbk underdrive pulley
By fastlt196 in forum Parts For Sale / TradeReplies: 0Last Post: 03-24-2009, 03:47 PM -
Underdrive Pulley
By Sarge in forum GTOReplies: 15Last Post: 09-18-2008, 11:24 AM -
Underdrive Pulley-Does It Need OD Alternator Pulley
By Eddie 70 in forum External EngineReplies: 16Last Post: 10-01-2007, 08:23 AM -
Underdrive Pulley?
By 02bluez28 in forum External EngineReplies: 18Last Post: 06-18-2007, 04:47 PM -
Underdrive Pulley
By 2001bird in forum Internal EngineReplies: 4Last Post: 10-25-2006, 07:37 AM
