Results 1 to 3 of 3
Thread: fluid leakin from rear U joint?
09-27-2007, 06:52 PM #1JOSEY FUCKING WALES!
- Nov 2005
- College Station TX
Black- 2000 &2002 Z28
Im almost positive I know what this is but im a n00b and need some advice....
My tranny has been out for a month or 2 now (or so i think) and when i jacked up the front of the car to look at the tranny again and make sure everything is hooked up right.....
Well when i was getting out from under the car I looked towards the rear and noticed a fresh puddle under the rear end....I took a look out of it and it looks like this oil is coming out from around the rear u joint....
Any ideas?
09-28-2007, 02:46 AM #2
Sounds like pinion seal leaking.
09-28-2007, 03:32 AM #3Junior Member
- Sep 2007
- Columbus, GA
Yep. Or its leaking from the input shaft and snaking down the driveshaft.
Fluid Leaking From Tube to Differential Joint?
By slade8200 in forum DrivetrainReplies: 0Last Post: 09-24-2014, 07:10 AM -
rear end fluid coming out of the rear tire
By stangkillan101 in forum DrivetrainReplies: 6Last Post: 06-24-2011, 07:42 PM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
know where I can find a gm brand rear u-joint?
By notfastenuff in forum General HelpReplies: 18Last Post: 10-21-2007, 08:24 PM -
Rear end fluid?
By Black02LS1 in forum DrivetrainReplies: 8Last Post: 05-15-2007, 06:26 PM
