06-24-2011, 01:15 PM #1
rear end fluid coming out of the rear tire
just put 373 gears in my 10 bolt but now i have dopeing "rear end fluid" coming out of my passenger rear end there is doping all in the inside of the rim and also through out the rear weals if any one could tell me what it could be that would be awesome cause i gotta get my car ready for fbodybeachbash
06-24-2011, 02:09 PM #2Senior Member
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
Axle seal
06-24-2011, 02:31 PM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
^This.
06-24-2011, 02:50 PM #4
06-24-2011, 03:57 PM #5
I agree... Simple fix
06-24-2011, 07:03 PM #6
agree with all the above. i pretty much change my seals everytime I pull an axle out. I put a little gear oil around the lip so the axle slides in easy.
Its an easy fix.
06-24-2011, 07:42 PM #7Exalted Cyclops
- Feb 2007
- San Diego, CA
Axle seal x eleventy billion.
You've got to crack the pumpkin to get at the c-clips to remove the axle. Needless to say the brakes also. Simple fix after that. If you don't have a seal removal tool (the preferred solution) try using the axle where the c-clip goes to pry the seal out. Worked for me when I was shade treeing things.
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
Rear end fluid?
By Black02LS1 in forum DrivetrainReplies: 8Last Post: 05-15-2007, 06:26 PM -
Rear End Fluid Capacity
By Wikid NaSSty in forum DrivetrainReplies: 7Last Post: 04-19-2007, 06:08 AM -
Rear end fluid?
By Hot Rod SS in forum DrivetrainReplies: 3Last Post: 12-17-2006, 09:27 AM -
Uneven tire wear on rear tire??
By renzo in forum Wheels and TiresReplies: 2Last Post: 11-20-2006, 04:30 PM
