Thread: Rear End Fluid Capacity
04-10-2007, 07:57 AM #1
Anyone know from experience approximately how much fluid the rear ends hold? I'm not sure if I read it right but I thought my Helms manual said the diff would hold about 1.5 quarts. I am thiking the manual meant only the diff and not the axles because I dumped in 2 full quarts as well as the 4 oz of limited slip additive and its still not up to the fill plug. I also have TA girdle which is supposed to hold a little more fluid than the stock diff cover. I need to know how much more oil to buy. Thanks.
04-10-2007, 03:05 PM #2
Only use the fill plug that is on the rearend housing. I have seen many people use the fill plug that is higher than the OEM plug and seen axle seals leak more and excessive blow by/fluid come out of the vent on the housing.
^ That is just my experience. I am running the same cover and always use the OEM fill plug and have never had an issue nor have I had an issue with any of the other rearends that I have built.
04-10-2007, 04:41 PM #3
04-11-2007, 07:22 PM #4
Thanks. I ordered another quart the other day assuming it wouldn't need anymore than that.
04-14-2007, 05:29 PM #5Member
- Indianapolis, IN
Silver- 2002 Trans Am WS6
My Strange 12-bolt took almost 6 quarts!
04-19-2007, 05:58 AM #6
04-19-2007, 06:05 AM #7Member
- Indianapolis, IN
Where on the axle housing? I didn't see one.
04-19-2007, 06:08 AM #8
Pass. side of the center just like the stocker.
rear end fluid coming out of the rear tire
By stangkillan101 in forum DrivetrainReplies: 6Last Post: 06-24-2011, 07:42 PM -
Changing trans fluid and rear end fluid
By 98Z28importslayer in forum DrivetrainReplies: 6Last Post: 07-29-2008, 08:33 AM -
Rear end fluid?
By Black02LS1 in forum DrivetrainReplies: 8Last Post: 05-15-2007, 06:26 PM -
Rear end fluid?
By Hot Rod SS in forum DrivetrainReplies: 3Last Post: 12-17-2006, 09:27 AM -
What is the Volume capacity of the power steering fluid resivoir?
By 2001 stripper in forum General HelpReplies: 0Last Post: 12-26-2005, 03:48 PM
