Results 1 to 20 of 21
09-18-2007, 05:43 PM #1
How hard is is to swap out a lt1 for ls1??
Hey everyone, I have a question for you all. I have a 1995 Trans am with A4. My buddy has a LS1 motor that came out of a 02 trans am.. Im wanting to swap out my lt1 for the ls1.. How hard is it to due.. Motor comes complete with cpu, harness and all.. Will it be a streight swap, or would i need to due any mods to get the ls1 in??? Im hoping you guys can help.. Or should I just build up the LT1 what do you think???
09-18-2007, 05:45 PM #2
IMO build up the LT1, the swap will be tough, your going to need to swap the wiring harness also not just the engine, totally different system.
09-18-2007, 08:35 PM #3
Yeah thats coming along with the motor.. would it be a problem switching to the ls1 harness.. ? I mean its a complete system...
09-19-2007, 02:52 PM #4
I have always been wondering the same thing, its hard to get a straight answer sometimes lol. Lets say there is no option and you absolutely have to swap an LT1 with an LS1 what needs to be done? Lets try not to get answers like "better off building the LT1 or better off buying one with an LS1" is it easier then swaping with a V6 or is it about the same work?
09-19-2007, 02:58 PM #5
09-19-2007, 08:33 PM #6Member
- Buffalo
I would think a 97 would be an easier swap than a 96 or older. The 97's got day time running lights and the alarm and the ls1 cluster and inside brain box.. and all that. So maybe more of the harness is like the LS1. However, I'm sure most of the engine hook ups are different.. I don't think it would be that hard though. Just start doing little by little. It can be done. How hard it is irrelevant in my opinion. Its just a matter of getting the harness and the PCM. And if you already have a 97 then you have the cluster and all that too.
09-19-2007, 09:56 PM #7live fast, die young.
- santa ana
metallic blue- 1969 camaro
you would need new motor mounts too
09-20-2007, 08:29 AM #8Junior Member
- Dec 2005
- ag town
pewter- 2000 ta
well from what i have heard from someone who has done if it was not worth it you have to change rack and pinion and k-member but since you have everthing i would say go for it you will get a lot more power out of it and in the long run i think you will be happy with your results you have everthing any way so get ur done good luck
09-20-2007, 04:49 PM #9
09-20-2007, 05:58 PM #10Member
- LA
Grey- 2010 Camaro 2SS/RS CGM
09-22-2007, 11:00 PM #11
Thanks guys for all your input.. Lets keep it coming, its getting me closer to do what i have to do....
09-24-2007, 01:46 PM #12Member
- Jun 2007
- NC
green- 94 z28
09-28-2007, 03:54 PM #13
save the dough and just get a built lt1/4 shortblock or stroker
09-28-2007, 04:52 PM #14
Look into the LE1 kits, I forgot what it stands for...
09-29-2007, 05:11 AM #15Junior Member
- Sep 2007
- long island NY
- lt1 powerd c10
im in the process of puttinga 2002 vette ls1 in a 1957 bel air . as long as you have the right tools you can do anything. but if you have to ask if its hard or easy than your not knowlegeable enuff to do the job.
09-29-2007, 07:11 AM #16
Yea thats easier tho, but ur right. With the right tools anything can be done.
09-29-2007, 09:38 AM #17
09-29-2007, 12:55 PM #18
09-30-2007, 09:17 AM #19
That's a good one, really. Seriously though, i've been busy putting an LT1/M6 in a my latest f-body - Polo Green '94 Z. Not really a fan of the green, but I bought the car in excellent shape inside and out with no trans or motor for dirt cheap. It will be a mildly modded daily driver.
10-01-2007, 11:53 AM #20
Dude,, First off. The main idea here is to get input from someone who has done the swap or knows about it... I mean a Fbody is totally different then your 57 belair.. 1. you dont need to worry about emissions., seond you did not specify wetheryou are going carb, or fuel injected. wich brings the question to wether you need new cpu unit, wiring harness, air pumps for smog regulations, different k member, motor mounts,, I mean any one could just rip out a motor from a car and get one in with "the right tools" Its about doing it right, and making it work.. for what its intended for.... Sometimes You have to think outside the box.....BRO!!!
Question: V6 to V8 swap? Is it hard?
By hpglow in forum Camaro / SSReplies: 20Last Post: 06-11-2009, 10:50 AM -
Question: How hard is it to swap to an LS2?
By bdg7884 in forum General HelpReplies: 5Last Post: 07-15-2008, 05:03 PM -
Radiator swap.. is it hard to do???
By blackTA6585 in forum External EngineReplies: 3Last Post: 08-17-2007, 08:56 PM -
how hard is a th400 swap
By crawdad369 in forum Automatic TransmissionReplies: 1Last Post: 05-24-2007, 07:10 PM -
Ls1 Swap Into My Lt1 How Hard?
By camaro_ss_97_ in forum LT1Replies: 12Last Post: 02-03-2006, 09:21 PM
