Results 1 to 2 of 2
Thread: how hard is a th400 swap
05-23-2007, 09:18 AM #1Junior Member
- Feb 2007
- Little Rock, Ar.
- 1998
allright I have a wrecked 98 z28 I would like to make a drag car. Not going to drive on the street so I figure a th400 would be cheaper than an80e and the tc's are too. Any input?
05-24-2007, 07:10 PM #2Junior Member
- May 2007
- Daytona,Fl
It's a pretty straight forward swap. I used a m6 cross member, had a custom steel drive shaft made to handle the trans brake and nitrous leaves. The bell housing bolts right up but you will need to leave out one of the bell housing bolts. I used an adapter made by JW Performance to use a stock style gm convertor to bolt to the crank and the convertor. Hope this helps.
swap from t56 to th400 any input
By 1-BAD-SS in forum Automatic TransmissionReplies: 0Last Post: 04-10-2012, 03:24 AM -
Help: Doing a 6spd swap to a TH400
By 00BlackBird in forum Automatic TransmissionReplies: 11Last Post: 01-18-2010, 09:47 AM -
Question: V6 to V8 swap? Is it hard?
By hpglow in forum Camaro / SSReplies: 20Last Post: 06-11-2009, 10:50 AM -
Th400 Swap W/ Everything you need
By Frans96ss in forum Parts For Sale / TradeReplies: 0Last Post: 08-16-2006, 09:37 PM -
Ls1 Swap Into My Lt1 How Hard?
By camaro_ss_97_ in forum LT1Replies: 12Last Post: 02-03-2006, 09:21 PM
