Results 1 to 20 of 23
Thread: Call yourself a gearhead do you?
09-16-2007, 05:42 AM #1
- Retired Outlaw Sum Bitch
How often do you clean/inspect/change your:
Air Filter
Fuel Filter
Trannie oil
Rear Diff fluid
Brake Fluid
Power steering fluid
PCV Valve
Clean your MAF
Torque your driveshaft and axle bolts
Replace spark plugs
09-16-2007, 05:48 AM #2
- Nov 2006
- Indianapolis
When its dirty, 'bout every 7-10k
every 30k. More than that is overkill.
every 50k.
30k or so.
every 2 years.
once so far, my car has 62k or so.
not yet....
one time. It made no difference I could tell.
Never. Still has OE torque.
Changed them with a new set when I put the Hookers on last Fall. Love those double platinums!
However, I inspect most of these things monthly or better.
09-16-2007, 05:53 AM #3
09-16-2007, 06:23 AM #4
- Jan 2007
- Mayberry....(Indiana)
Black- 2004 GTO
I don't do any PM.....
I just drive it....
.....as a matter O' fact, I don't even know what it looks like under the hood....All joking aside, about every oil change, I give it a good once over, so every 3k
09-16-2007, 12:18 PM #5
- Sep 2006
- Newcastle,De.
04 GTO QuickSilver- 95 MarkVIII wifey white
Some of these more often than others but I touch base with all of these plus other nuts,bolts, and hose clamps.
09-16-2007, 12:21 PM #6
09-16-2007, 01:17 PM #7
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
every day
09-16-2007, 01:38 PM #8
Air Filter - clean it every 2 months or so...K&N...last time was june
Fuel Filter - haven't yet
Trannie oil - haven't yet
Rear Diff fluid - haven't yet
Brake Fluid - haven't yet
Power steering fluid - haven't yet
PCV Valve - haven't yet
Clean your MAF - cleaned it when i did the filter last...june
Torque your driveshaft and axle bolts - haven't yet
Replace spark plugs - haven't yet
i've owned the car since may so many of the things that i haven't done yet i was planning on doing when i take the car out of storage next spring.
09-16-2007, 01:41 PM #9
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
I change the bitch in the passenger seat as often as weekly
09-16-2007, 01:44 PM #10
09-16-2007, 01:44 PM #11
09-16-2007, 01:50 PM #12
I won't let Wal-Mart touch my car.
Air Filter - Usually at least once a month inspect. Replace about every year
Fuel Filter - every 20K miles
Tranny oil - every 30K miles just got changed about 7,500 ago
Rear Diff fluid - Every year
Brake Fluid - I personally haven't yet.
Power steering fluid - just changed about a month ago
PCV Valve - Enignes only got about 36K on it
Clean your MAF - Don't have one hahahahaha.....Speed Density
Torque your driveshaft and axle bolts - Got torqued about 7,500 ago when the tranny was removed
Replace spark plugs - about 500 ago. Every 30K to 50K
09-16-2007, 01:53 PM #13
i never change my pcv valves lol I've never encountered a bad one either. not saying its bad practice. they are cheap and MOST of the time they are pretty easy to replace. the ones that screw in however can become a nightmare if they break or get seized in there. the air filter i change/clean when they are dirty, the fluids i change maybe every 20k? but they do get done. the gas filters i do every 20k as well. the one filter people neglect is their gas filter. an old gas filter can cause all kinds of driveability issues/ lack of performance that people never realize. I have stick shift vehicles, which dont need there oil/fluid changed as frequently as an automatic. I recommend FLUSHING an auto trans every 30k.
09-16-2007, 03:49 PM #14
- Feb 2007
- San Diego, CA
I do it on a regular basis at recomended intervals if not sooner. I usually just pay someone else to do the dirty jobs. Not that I can't, I just don't want to deal with the used oils anymore.
09-16-2007, 08:07 PM #15
09-16-2007, 08:15 PM #16
I drive a thirdgen. So for all of those, choose:
She's running, I ain't fuckin with it.
09-17-2007, 09:38 AM #17
- Nov 1999
- over here...
Air Filter (i check that every time i check my oil...)
Fuel Filter (change that with every 3rd oil change)
Trannie oil (transfluid not much...)
Rear Diff fluid (rear diff is getting checked often cause my rear is about shot)
Brake Fluid (my brake fluid gets checked often, and is in need of changepain in the ass bleeding)
Power steering fluid ( check this with the season changes...)
PCV Valve (never)
Clean your MAF (when i clean my filter)
Torque your driveshaft and axle bolts (i check them before i go to the track... but not all the time)
Replace spark plugs (with my fuel filter... every 3rd oil change... some times i'll let them go if they look good enough...
09-17-2007, 02:38 PM #18
- Thornton, CO
Air filter gets fresh oil every 6 months.
Fuel filter is in the car no longer than 10,000 miles.
Tranny fluid got changed at 5,000 miles.
Rear diff is going on 7,000, getting changed very soon.
Brake fluid got changed at 6,000 miles after the swap.
Power steering fluid is at 7,000.
PCV valve is new once a year.
MAF gets cleaned when it needs it.
Driveshaft...routine checks. Axle needs a new bearing, getting that very soon.
Spark plugs once a year, roughly 4,000 miles.
I recently washed my car. It was Saturday night. Got dark. The car was on jackstands and didn't have a passenger front tire.
09-17-2007, 05:06 PM #19
09-17-2007, 07:31 PM #20
Done 6 of the 10 recently.
Gearhead Tattoos
By JDHedman in forum Almost Anything GoesReplies: 32Last Post: 01-19-2013, 08:08 AM -
Gearhead Woman
By KarrKraft in forum Almost Anything GoesReplies: 30Last Post: 02-14-2011, 03:25 PM -
Old Gearhead
By geihsj in forum New Member IntroductionsReplies: 10Last Post: 11-16-2010, 04:06 PM -
You know you are a gearhead when....
By Mr. Luos in forum Almost Anything GoesReplies: 64Last Post: 10-24-2008, 06:04 AM -
few questions for the new gearhead
By allforspeed in forum Camaro / SSReplies: 22Last Post: 06-20-2007, 10:26 AM
