Results 1 to 17 of 17
Thread: Oil Pan Leak!! HELP!!
09-09-2007, 08:16 AM #1Member
- May 2007
- City of Angels
Pewter Metallic- 2000 Chevy Camaro Z28
Ok so last night coming home i hear this thump under my car when im on the freeway...i guess something hit my car from under and cracked my oil pan
...the crack is at the bottom part of the oil pan and its small (you wouldn't be able to tell if you didnt see the oil seeping out)
Well the oil was seeping out fairly quick so I drained it and bought a sealant (since the crack is tiny)...After I clean the area and apply the sealant and let it dry what do i do next? I think i read somewhere around here to put tape and then some more sealant after the first application...is that right?? can someone please explain?? i want to do this right. Pictures would be great also.Thanks.
09-09-2007, 09:21 AM #2Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
What kind of sealant did you use?
09-09-2007, 10:51 AM #3Member
- May 2007
- City of Angels
SealAll contact adhesive and sealant...got it at autozone..it says its gas and oil resistant...plus in the back it says its good for "repairing and maintaining oil pans and oil lines etc."
09-09-2007, 01:11 PM #4Simpsons Did it!!
- Mar 2007
- Minnesota
As long as you covered the crack good enough, one more time might not hurt, or try putting in some oil and see what happens
09-09-2007, 03:13 PM #5Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Change the oil pan and gasket. Sheesh..............
09-09-2007, 03:22 PM #6Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
09-09-2007, 09:02 PM #7
09-09-2007, 10:47 PM #8
09-10-2007, 05:51 AM #9
I would agree with Sarge, Since the Oil pan is part of the structural integrity and rigidness of the motor i would replace the oil pan. No you dont have to pull the motor to change the pan.
09-10-2007, 06:10 AM #10Grand Imperial Wizard
I want him to replace the oil pan that is super glued with a new one and replace the old gasket with a new one at the same time. I see guys replace the oil pan and leave the old gasket on there and of course here come the leaks......so I always tell the kids...replace the pan and the gasket.
09-10-2007, 06:46 AM #11
Should be fine as long as you cleaned up the pan first for awhile, anyway.
This isn't a permanent solution either. First time that hunk-o-gunk falls off your oil pan due to heat, vibration, road debris, whatever, youre not going to know it for awhile, and you DONT want to run these engines low on oil.
Its a temp fix until you get the cash together and get a pan and gasket to replace it, and something I would keep a close eye on.
They do make "guard" type things you can attach to the bottom of your new pan if this is a problem in the area you drive in.
09-10-2007, 08:04 AM #12Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Since the engine doesn't have to come out, I would get a new gasket & take the pan to a welding shop & have them heliarc it.
I see no reason to trash a good pan for a small crack. But that epoxy has got to go!
09-10-2007, 10:16 AM #13Member
- May 2007
- City of Angels
ok so i filled her up with oil this morning and drove it to school...the sealant seems to be holding but i don't want to worry about it so i'll be replacing it as soon as i can get the money for it...besides now that i've been under there there seems to be another small leak.
Car is about to hit 100K miles so i guess its a good idea to just replace the seal and the oil pan. What would best...get a new one or weld the cracked one like rbob93 suggests?? Like i mentioned the crack is barely even noticeable.
09-10-2007, 02:47 PM #14
09-10-2007, 08:13 PM #15Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
I had my oil pan gasket replaced on my 2001 Z28 three months ago. The dealer told me they had to lift the engine from the motor mounts to remove the pan. They charged me $400. Did I get hosed?
09-10-2007, 08:21 PM #16Don't be afraid of the bottle!!! Be afraid of your tune!!!
09-13-2007, 12:12 PM #17Member
- May 2007
- City of Angels
Yeah for the time being i think i'll just get it welded...i'll change it in a couple of months when i get my new mods....thanks fellas
Help: OIL Leak!!!
By joedude02 in forum General HelpReplies: 7Last Post: 12-05-2010, 08:59 AM -
Help: oil leak
By sutie in forum Internal EngineReplies: 10Last Post: 10-25-2009, 05:34 PM -
Serious oil leak
By Eagle in forum Internal EngineReplies: 0Last Post: 09-28-2007, 05:54 AM -
ttop leak, hatch leak, and window motor problems
By ATCharming in forum General HelpReplies: 41Last Post: 07-23-2007, 03:30 AM -
how serious is PS leak?
By 02WS6dream in forum General HelpReplies: 1Last Post: 10-16-2006, 05:44 AM
