Results 1 to 2 of 2
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    how serious is PS leak?
    Hey guys--another 'rookie' question... I noticed about a year ago while under my car that there appeared to be a leak around a fitting at my stearing rack, and had it checked out to find it was a high-pressure line leak and that my pinion seal was also leaking. the dealer made it sound like this was going to eventually just blow apart and break other things in the process...and quoted me around 300 to fix it... Not relatively that much I guess (just rebuilt auto tranny ); but since i've only had to fill A LITTLE fluid once in the last year, i haven't worried too much about it. should i be more worried???
    Tampa
    2001 SS
    I personally would just spend the $300 bucks. If could "blow" at any point. Of course you would loose you're power steering if that happened, but you would also run the risk of burning up you pump if you loose all your fluid.
  1. Help: OIL Leak!!!
    By joedude02 in forum General Help
    Last Post: 12-05-2010, 07:59 AM
  2. Help: oil leak
    By sutie in forum Internal Engine
    Last Post: 10-25-2009, 04:34 PM
  3. Serious oil leak
    By Eagle in forum Internal Engine
    Last Post: 09-28-2007, 04:54 AM
  4. ttop leak, hatch leak, and window motor problems
    By ATCharming in forum General Help
    Last Post: 07-23-2007, 02:30 AM
  5. Leak #1 QB?
    Last Post: 09-18-2006, 06:46 PM
