Results 1 to 3 of 3
Thread: Oil pump replacement
09-07-2007, 10:47 AM #1Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
Is absolutely neccesary to replace the oil pump and timing chain while doing a cam install. I've only got 55K miles and dont beat on it non-stop. I have heard the early ones like mine (98) have had issues, is there any truth to that.
09-07-2007, 11:50 AM #2
I would recommend with an aftermarket cam you get a new oil pump. In fact, go to texas-speed and get the ported LS6 oil pump. Will provide you with an additional 10psi of oil pressure. Only 150$. As for a timing set, You cant be too cautious on getting parts that are cheap to buy but a bitch to install. Save yourself the hassle and go ahead and get a new one. No more than 130-160$ for a great timing set.
09-08-2007, 02:06 PM #3
just did a cam swap on my friend's 98 camaro. reused the oil pump as it was working fine. and his has more miles than yours.
http://www.ls1.com/forums/showthread.php?t=61848Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
Water pump replacement
By cascade in forum General HelpReplies: 5Last Post: 06-16-2011, 01:20 PM -
water pump replacement help
By machucam in forum External EngineReplies: 3Last Post: 10-11-2008, 04:25 PM -
a.i.r. pump replacement
By 02WS6dream in forum General HelpReplies: 10Last Post: 04-19-2007, 12:01 AM -
Fuel Pump Replacement
By LS1PowerBroker in forum External EngineReplies: 2Last Post: 09-05-2006, 07:50 PM -
By redz284u in forum General HelpReplies: 20Last Post: 10-07-2005, 03:08 AM
