Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 128
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Shock Replacement
    was doing some lowering springs and shocks on a 99 TA. figured i'd take some pics.
    http://tredalign.com/shockreplacement.htm
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    Nice...
    lift the car from the body
    Uh, isnt that the same thing...?? I think you meant to say "lift the body from the suspension"...?
    And in your last statment:
    "With all 4th gen cars, this happens. Water gets up into the upper mount pocket and rusts the nuts to the shock stud."
    You might want to warn your readers; To me this was the worst part of the install, it took me like 2 hours per side to dremel the nuts off each shaft, piece of cake after that...(you may want to mention how to get the nuts off too...?)
    good write up, other than those two suggestions...
    Regards,
    Todd
    #cajunhotrodder on instagram
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by 99'CajunFirehawk157 View Post
    Nice...
    uh, no. if you lift it from the suspension, the rear axle won't lower down. you put whatever you are going to use to lift the car, just as you would if you were changing a tire, on the body, not the suspension.
    i'll have to look into that.
    USA
    BLACK
    Z/28 LS1
    Great job Mrr23. What shocks/springs did you put on her? Is the ride alot harsher/firmer? (I ask because I am trying to decide what shocks/springs to go with)
    Thanks
    39466 USA
    Bright Red
    I wasnt saying your methodology of performing the task was incorrect, I was just saying the way your worded it sounds a lil off, to me anyway....but its kewl.
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by BREAKxNECKxSPEED View Post
    Thanks
    it was a customer's car. koni single adjustable and strano springs. he autocrosses the car.
    Ran into the rust issue VERY badly today.
    So bad, we had to order a new strut boot for the car. The boot and strut were fused together.
    I still have to see if I can save the strut...it has parts of the boot still on it. Should be able to cut it off with the dremel though and remove the rubber with heat.
    Canada eh
    99 TA
    same thing happened to me..
    orlando, fl
    2014 camaro 2ss/rs
    i don't know of anyone it doesn't happen to. well maybe cars that never see inclimate weather.
    Mine.
    But I couldn't get the nut off without air tools.
    Advice for cutting what is leftover on the strut off?? Dremel and heat?
    orlando, fl
    2014 camaro 2ss/rs
    i've had to use a torch and melt the nut then split it.
    I have the nut off.
    There is part of the entire strut boot fused to the strut.
    d
    2002 z28
    is there a tourque setting for the rear shocks??
    I go to solidly snug.
    d
    2002 z28
    thanks, i think i could tackle this install myself, save some money,
    thanks
    USA
    BLACK
    Z/28 LS1
    greatwhitez28 come do mine after you do yours hahahaha!!!
    d
    2002 z28
    sureeee, let me mess mine up first then ill know what im doing on yours. LOL
    ill let you know, but i think this is a great job to do in the winter while the car is sitting
    USA
    BLACK
    Z/28 LS1
    ^ hahahaha That was my plan! MUAHHHHHHHHHHHHHHHH!
    d
    2002 z28
    that a boy LOL
    39466 USA
    Bright Red
    Cool torq
    Quote Originally Posted by greatwhiteZ28 View Post
    All the fbody torque values you will never need...http://cofba.org/users/orion98/fbody.pdf
  1. Front Shock Boot Replacement
    By slade8200 in forum Suspension and Handling
    Last Post: 08-09-2016, 10:00 AM
  2. shock and strut replacement
    By dethinboots in forum GTO
    Last Post: 12-09-2014, 05:40 AM
  3. front shock lower springs, shock mount mod?
    By JayTA98 in forum Suspension and Handling
    Last Post: 12-24-2011, 03:48 AM
  4. need alingment after shock replacement?
    By 00camaro16 in forum Suspension and Handling
    Last Post: 04-26-2011, 08:42 PM
