Results 1 to 2 of 2
    Member slade8200's Avatar
    NH
    02 SS #8850
    Front Shock Boot Replacement
    I'm in the middle of my front shock replacement, and on one of them I cut the boot like an idiot to get at the shaft so I could cut it... later realizing I should have slipped the blade in between the upper mount and the top of the boot to cut the non-hardened threaded part... and I'd still have my boot intact.
    Anyways I want an OEM boot but the p/n on the boot (22114311) comes up as discontinued. I got a Driveworks boot from Advance but this only has the boot and the bumper, it doesn't have the thick metal part in it like the OEM one, which I believe is needed to properly bolt the upper mount to.
    Any idea on what the new p/n is?
    I am guessing that the part may be discontinued completely. Every now and then the F-body specialty vendors will have some NOS parts in stock so you may want try shopping the web.
  1. shock and strut replacement
    By dethinboots in forum GTO
    Last Post: 12-09-2014, 05:40 AM
  2. front shock lower springs, shock mount mod?
    By JayTA98 in forum Suspension and Handling
    Last Post: 12-24-2011, 03:48 AM
  3. need alingment after shock replacement?
    By 00camaro16 in forum Suspension and Handling
    Last Post: 04-26-2011, 08:42 PM
  4. Bad front shock??
    By cobrahunter in forum Suspension and Handling
    Last Post: 11-08-2007, 01:33 AM
  5. Shift boot replacement
    By Necction in forum Firebird / WS6
    Last Post: 12-13-2005, 08:35 AM
