Results 1 to 2 of 2
09-04-2007, 07:09 AM #1Junior Member
- Oct 2005
- Midwest
White- 1997 Grand Prix GTP Coupe
Need Fuel Pressure specs for an '02 5.3 Flex Fuel
Hi, my buddy's '02 Tahoe flex fuel 5.3 gave him problems this morning. He said he had to hold the gas pedal down some to keep it from dying at idle and at lower speeds. I did some checking over of it and it had no DTC's or other obvious problems. I did do a fuel pressure check and got 42 psi at idle, 52 psi with the vacuum line off the regulator. Engine off with the pump priming I got 52 psi then it drops down to 46 psi almost immediately after the pump stops priming, then it bleeds off another 10 psi in 10 minutes in pressure leaving the key ON & the engine OFF. It will eventually bleed all the way down to 0 psi. Pulled the vacuum line & saw no fuel come out of the fuel pressure regulator while the system was pressurized. So, is this ok? If not can you get me some specs for this truck's fuel system? TIA.
09-04-2007, 08:18 AM #2
i think it is around 55-60 psi. change that fuel filter
Question: 5.3 flex fuel mods
By jimmyz454 in forum General HelpReplies: 7Last Post: 05-27-2014, 02:20 PM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM -
GM Flex Fuel question
By Nastyfoot in forum General HelpReplies: 5Last Post: 08-18-2006, 04:31 AM -
E-85 flex fuel who using it????
By stage274 in forum General HelpReplies: 93Last Post: 05-30-2006, 02:26 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM
