    Love buying generic GM's Nastyfoot's Avatar
    Wine em,Dine em' and 69 em'
    Black, Black
    2011 "Generic" Gasser
    GM Flex Fuel question
    Some of the newer GM's are fixed with the flex fuel program. 8 cyl. when needed then back to only 4 cyl. when not needed.
    My question is can you override this sytem and keep it in 8 cyl. full time.The salesperson said no. I'm interested in an 06 Impalla SS but I'm leary of this program and the "newness" of it. Is it reliable too?
    Member Z27's Avatar
    Northern KY
    Green Red Black
    71 SS 00 SS 06 Impy SS
    That would be the DOD or displacement on demand. Just picked up a new Impy SS and was wondering if it was possible to make it run on 8 all the time. The transition from 4 to 8 and back is pretty seemless. This thing will definitely merge into traffic.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I'm sure given time, the aftermarket tuners you can purchase will have a feature to modify the PCM.
    SteveC
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    It's probably possible to make it run on 8 all the time, but why would you want to?? Why use double the amount of fuel when you're sitting in traffic?? The transition is practically seemless, the moment you punch the gas all 8 cylinders are engaged, I don't see the advantage to leaving it in 8 cylinder mode when you don't need all the power.
    Member Z27's Avatar
    Northern KY
    Green Red Black
    Quote Originally Posted by Wesman View Post
    It's probably possible to make it run on 8 all the time, but why would you want to?? Why use double the amount of fuel when you're sitting in traffic?? .
    They run on all 8 when sitting in traffic. The only time I see it change is on a steady cruise. You can monitor the operation on the info center in the dash.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    If there isn't any problem with the system why would you want to bypass it?
  1. Question: 5.3 flex fuel mods
    By jimmyz454 in forum General Help
    Last Post: 05-27-2014, 02:20 PM
  2. 2009 Ford Flex - Hot Rod Ford Flex
    Last Post: 08-10-2009, 10:00 PM
  3. Need Fuel Pressure specs for an '02 5.3 Flex Fuel
    By Fortune50 in forum GM Trucks
    Last Post: 09-04-2007, 08:18 AM
  4. Flywheel / Flex Plate question
    By OutToWinPAHC in forum General Help
    Last Post: 03-21-2007, 12:05 PM
  5. E-85 flex fuel who using it????
    By stage274 in forum General Help
    Last Post: 05-30-2006, 02:26 AM
