Thread: Hard 1-2 shift
    Member 79Firebird_99TA's Avatar
    ATL
    99 Trans Am
    Hard 1-2 shift
    The TA is shifting hard from 1st to 2nd. I have no codes and it is not in limp mode. This just started last week. Any ideas?
    Florida
    2000 Z-28
    ttt
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    Broken or stuck accumulator or bad PCS would be my guess or possibly ball came through the plate
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    My 01 Z28 shifts very hard from 1st to 2nd, I have a billet 2-4 super servo, and a transgo shift kit #3 washer.
    If you have any of these components that could be why the shift is that hard.
    SteveC
    ATL
    99 Trans Am
    Well the thing is .....it never did until recently. I must say that I like it....but it's different.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    You'll like it until it fails. Get it checked out.
    Dana
    Jun 2006
    Calimesa, California
    "My 01 Z28 shifts very hard from 1st to 2nd, I have a billet 2-4 super servo, and a transgo shift kit #3 washer."\
    Take out all of the washers, I never use them in any of my Performance buildups. This should make a big difference. If the 2nd feed hole on the separator plate is larger than .093", that can cause hard 1-2 part throttle shifts. Start with taking out the washers, and see what happens.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    Quote Originally Posted by Pro Built Automatics View Post
    I actually like how the vehicle shifts, and have no problems with it. You are obviously far more experienced in the automatic transmission field than I will ever be.
    I had the transmission work done by a professional shop (Mike's) in Poway, and I trust that the work was done correctly. It was Mike's idea to swap the stock LS6 servo out for this unit.
    Thanks for the tip.
    SteveC
  1. Help: Hard to shift need help please!!
    By SuperSport Ron in forum Drivetrain
    Last Post: 11-16-2012, 07:51 AM
  2. Help: Hard to shift after using reverse!
    By Ryaleon in forum Manual Transmission
    Last Post: 09-27-2010, 03:32 PM
  3. Why is my T56 hard to shift?
    By darkvader0 in forum Manual Transmission
    Last Post: 03-05-2008, 05:01 PM
  4. HARD SHIFT problems!!
    By airmaxon1 in forum Automatic Transmission
    Last Post: 09-14-2007, 06:57 PM
  5. hard to shift
    By GEARHEADNATE in forum Manual Transmission
    Last Post: 12-19-2005, 09:13 AM
