Thread: Nib File?
    Senior Member 02ultraZ's Avatar
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Nib File?
    I painted my nose peice and front fender on sunday but got blotches in the base coat. I resprayed it and the base coat turned out great but I then got one large sag and two tiny runs on the nose piece in the clear coat. I just bought a tool called a nib file from the auto body supply shop and i am going to attempt to file down the runs. My question(s) are has anyone ever used this type of file? If so what was your outcome? And do you have any tips that could help me avoid problems? They paint is only two days old, I would say that the run is 1/16 of an inch thick, if i take off the top of the run, do you think inside the run the paint will still be liquid or soft? Once i have filed down pretty far should i then wet sand or finish it another way? I know that was a lot of rapid fire questions any help would be greatly appreciated.
    -Mike
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Inside may be still soft so I would allow it to cure out first.
    Never used a NIB File but have used other methods.
    Take off the buildup untill it's almost smooth, then finish up with wet sanding.
    I prefer to use a stick like a thick paint stirrer wrapped in wet or dry paper & plenty of water from a slow hose. Use a squeegee to wipe the water off & check your work after a few strokes.
    I'd use 320 & finish with 600.
    Runs in clearcoat are easy to fix because you can reblend that area easily if you mess up.
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Quote Originally Posted by rbob93 View Post
    Thanks for your help, i appreciate your information. I will try this in a few days once the clear coat is really hard.
  1. someone want to look at a file for me?
    By 0rion in forum Computers / Gaming
    Last Post: 04-26-2011, 07:24 PM
  2. PDF File Crack??
    By rbob93 in forum Computers / Gaming
    Last Post: 01-18-2008, 10:20 AM
  3. Anyone ever file Chapter 7?
    By Eubee in forum Almost Anything Goes
    Last Post: 09-12-2007, 06:17 PM
  4. HPtuners .BIN file
    By TTA_AWD in forum Computer & Tuning
    Last Post: 08-31-2007, 11:09 PM
  5. How do I add Music to an AVI file?
    By BillyT in forum Almost Anything Goes
    Last Post: 02-21-2006, 01:23 AM
