Thread: HPtuners .BIN file
08-10-2007, 12:38 PM #1Junior Member
- Montgomery, AL
red- 2000
HPtuners .BIN file
does anyone have a file for a tune for a car with just longtubes, exhaust, intake & free mods? I have already taken off the codes. Anything else I can do to give it more hp with hptuners?
08-10-2007, 07:25 PM #2
log in and search the tune repository.
08-22-2007, 05:59 PM #3
I need one as well, I looked on HP tuners but i didnt find one for my year... What would i need to tune any way?.. Jus add some timeing..? I have the same mods
1999 Pontiac Trans Am A4:
371.7 RWHP---440.2 ft/pounds
Best Time:
12.84 @ 106 MPH
(Bandimere Speedway Elevation: 5860 Feet)
http://www.kuruptkustomscarclub.com
08-23-2007, 02:31 PM #4
it doesn't have to be the same year.
08-29-2007, 05:37 AM #5
http://www.hptuners.com/customers/ There are several LS1 tunes (several variations and years) there after you log in and go to the tune repository. There are 10 1999 tunes there, but I agree, you shouldn't have to use a 1999 tune.
08-29-2007, 08:24 AM #6
Yeah i seen that the other day, I was going to the track today and try out a few.. But The rain kinda messed that up for me..
08-31-2007, 07:08 PM #7
Wouldnt you have to use the same tune for 98's?
08-31-2007, 11:09 PM #8Jesus died to save you!
- North Olmsted, OH
Navy Blue Metallic- 2000 Camaro Z28
Do not download the tune and write it to your car directly. Open your stock tune and the tune for longtubes in the compare menu. Then look at what was changed. then copy and paste from one tune to the other. That way you can see what the changes where and hopefully you can learn from that. Then Save the modified tune to a new file. Write calibration Only then go for a drive and Log your results.
Good Luck!Last edited by Killer_bluebird; 08-31-2007 at 11:34 PM.
2000 NBM Camaro Z28
Mods:
SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
HPTuners Pro
By 99bta6 in forum Parts Wanted / TradeReplies: 0Last Post: 03-18-2010, 03:16 PM -
Wanted: 99' Hptuners
By Mark8fish in forum Parts Wanted / TradeReplies: 0Last Post: 06-17-2008, 10:19 AM -
tr224 112 bin file hptuners.....
By 99vader in forum Computer & TuningReplies: 6Last Post: 02-22-2008, 01:10 PM -
PLX accelerometer w/ HPTuners
By dougcw in forum Computer & TuningReplies: 0Last Post: 06-17-2007, 01:37 PM -
i got hptuners
By mrr23 in forum Computer & TuningReplies: 7Last Post: 12-01-2006, 01:35 PM
