08-26-2007, 05:54 PM #1
will going bigger rims/tires make faster? stock to 275+
well car is stock but has NX. has stock 245's on now and before gettting some more DR's would doing a swap of bigger size make a diff on the strip .
sure there might be more thread on the ground but i even heard doing some 315's will slow the car down from presoios?
08-26-2007, 06:54 PM #2
when you grip and your rearend doesnt it'll be little slower.
i guess it depends on what wheel size and profile to determine the tire height
08-27-2007, 04:36 AM #3Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Weight has more to do with it than Height.
The larger the wheel size the heavier it is even if the tire height remains the same..
I went from 16's to 18's and it is definetly harder to turn the tires over.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
08-27-2007, 05:02 PM #4
i went from the stock wheels and 245/50-16 to 17 x 9.5 and 275/40-17 and lost .05. both tire sizes are same height. the wider tires and wheels did two things. added weight and friction. you now have to over come those two forces.
08-27-2007, 05:09 PM #5
08-27-2007, 05:10 PM #6
no, a half a second is .5. i lost five hundredths .05.
08-27-2007, 05:23 PM #7
bigger better faster build
By mark21742 in forum GTOReplies: 238Last Post: 04-24-2012, 08:56 AM -
FS: Stock 4-16x8 polished rims w/ stock eagle tires
By Long Beach in forum Parts For Sale / TradeReplies: 4Last Post: 01-24-2007, 10:11 PM
