Page 1 of 12 12345 ... LastLast
Results 1 to 20 of 239
    mercersburg pa
    hugger orange
    2004
    bigger better faster build
    Well last week I'm sure most of you know I hydrolocked the motor in my 04 GTO and blew #7 rod out the side of the block and oil pan... Now for the ressurection
    This week pulled the motor out and tore it down.
    Reusing the ported/polished and milled 241s for now,
    238/242 .595/.595 112 Trickflow cam
    Adjustable double roller timing set
    Melling hv oil pump
    7.400" pushrods(if possible)
    Now the fun stuff=
    Fully forged 404ci stroked 6.0l iron block
    Edelbrock Proflo XT intake (jus came in yesterday... Its hugh!)
    60lb injectors
    Also while the motor is out I'm doing a big cleanup and deleting parts=
    ABS gone
    TC/cruise unit gone
    Computer relocated under the dash
    Wilwood manual master cylinder and re running new lines (if you have not tryed using the new eazy bend lines you MUST and will love them)
    Flaming River manual rack to delete the power steering assy
    Also possibly relocating the coil packs if the valve cover covers will not fit with the new intake.
    I'm still running the stock 04 hood and pretty sure it will hit the intake so a might need to do some custom metal work to the hood for clearance... Thinking I might need a small hump like the older Eclipes
    I have some pics sofar and will be taking more as I go!
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Yeesh!!! You converting the car to full race specs?
    mercersburg pa
    hugger orange
    2004
    we will just say it will be a fun toy when i get it done
    but yes it will see the track
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Quote Originally Posted by mark21742 View Post
    Melling hv oil pump
    Now the fun stuff=
    60lb injectors
    ABS gone
    TC/cruise unit gone
    Sounds more like a grocery getter, LOL!
    That thing's gonna be potent! May have to run east to check it out when your done!
    New Jersey
    Torrid Red
    2004 GTO
    Nice build. Itll be a monster again in no time.
    mercersburg pa
    hugger orange
    2004
    The new manual rack and master cylinder came in today and are sitting on the livingroom table.
    Oil pan still being shipped
    Just ordered a fast 90mm tb
    This morning before work I port matched one of my already ported heads and one side of the intake. (I forgot how quick aluminum shaving cut your feet up when they get in your boot) lol
    Hope to pull the stock rack tonight when I get off work
    North Jersey
    2004 GTO M6
    My arms are hurtin just reading about the manual rack.
    mercersburg pa
    hugger orange
    2004
    With the extra turn lock to lock it shouldn't be that bad... I've been moving the car around with the power steering and motor not running lately lol now that is work
    mercersburg pa
    hugger orange
    2004
    Well 9 more hours till I get home and calls me to say another box has arrived from Fedex, but she won't open it or tell me how big it is...gotta love women and there twisted sense of humor, this is torture
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Sounds like things are coming along Mark.
    mercersburg pa
    hugger orange
    2004
    Yup getting there! Women are evil, but I'll get my revenge by locking myself in the garage all weekend to spend quality time with the car
    Member JAX04's Avatar
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    2004 Pontiac GTO PBM A4
    sounds like fun, are those ported 241s gonna flow enough air for a 404? Not sure, thas why i asked.
    on another note about me, Ive pretty completed my rearmount turbo build. I got most all of the piping for free so i figured what the hell. Im looking for a good donor motor at a good price to start forging, then when the motor is out, ill do a front mount build
    mercersburg pa
    hugger orange
    2004
    The ported 241s will work, but better heads are in the future. All the parts are in but the injectors (should be here begging of the week.
    The motor should be here in an hour or two
    mercersburg pa
    hugger orange
    2004
    JAX04 it sounds like you have a fun build going on too!
    mercersburg pa
    hugger orange
    2004
    Got the engine put together, dropped in (did not clear the hood lol), most of the brakelines re ran, master cylinder mounted, and the new rack mounted and hooked up but its the wrong rack (turn the wheel to left and the tires turn to the right) Summit made it right and is ending the correct rack to me
    Florida
    1999 TA WS.6
    Holy Heck! That Pro Flo is really tall!
    Looking good Mark!
    North Jersey
    2004 GTO M6
    HO...LEE...S**T!!! Gonna need a scoop for that hood!! I like it though.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Lookin good, now that the intake is so high you can make a swamp buggy out of it
    Just curious did you check your diff after you hydrolocked the motor, there is a chance water could have found its way down the vent tube.
    mercersburg pa
    hugger orange
    2004
    Engine specs=
    2002 6.0L cast iron truck block
    Mahle -12cc forged dish pistons
    Eagle 6.125 4340 forged H-beam rods
    Eagle 4.000 4340 forged crank 24x reluctor
    ARP Main Studs
    Mahle rings
    King bearings
    TrickFlow 238/242 .595/.595 112 lsa cam
    Ported/ polished/ milled 241 heads
    Edelbrock Pro-flo XT intake
    FAST 90mm tb
    Edge (motron) 60lb injectors
    Pacesetter lts
    Dual 3" exhaust
    This build was one of my dreams
    mercersburg pa
    hugger orange
    2004
    No I didn't check the diff... But I will now lol. The IRS sits up pretty high so it "should" be fine, the air filter sat very low (right behind the driverside fog light) and that is why it sucked water
  1. AMD's new FX chips let gamers build faster PCs at lower pric
    By Ed Blown Vert in forum Computers / Gaming
    Last Post: 10-23-2012, 04:30 PM
  2. 434ci Small-Block Engine Build - The Bigger Mouse
    Last Post: 02-03-2012, 11:00 AM
  3. 500CI Chevy LS1 Engine Build - How To Build A 500C
    Last Post: 02-17-2009, 07:10 PM
  4. will going bigger rims/tires make faster? stock to 275+
    By greatwhiteZ28 in forum Wheels and Tires
    Last Post: 08-27-2007, 05:23 PM
  5. Is the A4 really faster than a M6
    By q1234567890 in forum GTO
    Last Post: 03-26-2006, 07:54 PM
