    Lubricant
    Guest
    Click / clunk when changing gears or breaking..
    I went under the car, moved the driveshaft around and the u/joints are not the source of the play in the drivetrain..
    I took my T/A perf rear end housing cover off.. no metal shavings, and a slight bit of play on the gears inside. (Possibly normal??)
    All gears in the rear look good.. Nothing looked abnormal.
    Can the source of a click/clunk when shifting 1-2 2-3, and breaking be from the tranny?
    Tranny mount?
    In neutral when I hit the breaks when moving fwd, it gives a initial click, and thats it... Shifting from 1-2 2-3 I can sometimes hear it, but not often and when I do hear it, its a loud click like a slap on my bear ass..
    I never hear it in reverse...
    Any ideas?
    Exhaust is clearing everything just fine....
    I looked at the tranny mount, could not tell if it was broken...
    Is ANY level of play in the rear acceptable? Or should it be as tight as a teen?
    I should add, 02 WS6 33k miles..
    LS1 Wizard 00BadBrd's Avatar
    Foxboro,Ma
    2000 Trans Am
    I had this problem ,Not sure if it will help but..... My rear pass side exhaust hanger would Clink pretty bad when shifting. And as far as play... there shouldnt be to much get a dial indicator and check it but with that low of miles I doubt it.
    sounds to me like your tranny mount bushing took a shit on ya...
    Virginia beach
    SOM
    sounds like what I have, dunno what it is, will try the tranny mount...
    does your shifter move up and down when you get on it?
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    I know you may think this is dumn, but I had a similar incident with mine. turns out it had nothing to do with drivetrain itself. my rear passenger side caliper was extremely loose. Seriously thought I had a problem in the drivetrain too....
    uhhh well that might depend on location, cause around here, Tight and teen don't fit in the same sentence, how bout "Hotdog in a Hallway".
  1. MPH Gain changing gears
    By Durango in forum General Help
    Last Post: 07-01-2011, 07:28 AM
  2. Changing Gears On A 6 Speed Auto
    By I AM AN ARMY VETTE 2 in forum Corvette
    Last Post: 06-16-2007, 06:31 PM
  3. Hazard Problem (Click, Click, Click) but no light
    By Player87 in forum General Help
    Last Post: 05-31-2007, 06:37 PM
  4. Breaking in new gears.
    By LS1 Eddie in forum Drivetrain
    Last Post: 12-31-2005, 05:19 PM
