05-30-2007, 06:54 AM #1Junior Member
- May 2007
- South West of Germany
Silver- Pontiac Trans Am 1998 LS1
Hazard Problem (Click, Click, Click) but no light
Hi.
First of all I want to say sorry for my bad English.
I live in Germany and I have a Pontiac Trans am 1998.
The Preowner of the car imported it to Germany and in Germany it is necessary to have yellow turn signals. So how to do with a Treans Am with totaly red taillights. They just mounted a new lamp for reserve (driving backward) and changed the wires and the bulbs of the original reserve lights.
this you can see on this picture.
I have rewirde all the cables in the correct way now, but there is one big problem left. I have no Hazard (warning light) anymore. Before this everything worked, but no it isn't working anymore.
But when I try to start the Hazard, I hear the click click click sound out of the module very fast and after 1 second it is the normal speed. The wires I have checked. They are all ok.
do you know what i have to do??
thanks a lot and best regards,
05-30-2007, 07:27 AM #2
check bulbs, might have one blown, it happens. try using turn signals and see if they work and see if they all illuminate when you you have parking lights on. The bulbs blow in these cars, its common and they can do some weird crap. Also make sure you install the correct bulbs.
05-30-2007, 07:49 AM #3Junior Member
- May 2007
Hi.
I went down to my car to check.
All bulbs work fine when I pull on the turn signal and the parking lamps also work fine.
when i put on the hazard (warning light) i only hear the sound of click click cklick. The green arrows in the cockpit dont light up and the lamps also dont work.
05-30-2007, 08:22 AM #4Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
I cant help but i cant tell you these cars have crazy light problems sometimes, more common with high mile cars. My friedns T/A when it hit 125k went crazy sometimes one headlight would work sometimes none sometimes only 1 brake light sometimes all. Maybe his car was haunted though. One of our friends did die in it so we blamed his ghost.
05-30-2007, 08:43 AM #511 Second Club 11.34
- Aug 2006
- Streetsboro, Ohio
Red- 1998 Firebird Trans AM
First go back to basics. Disconnect all the stuff you did. See if it works as designed.
05-30-2007, 10:48 AM #6Junior Member
- May 2007
OK there is one big problem in going back to basics.
I forgot to wirte down what I did at that time, so I am not able to do this.
Look here
can you tell me where I have to check the wires if they got power.
The Orange and the Brown go to the hazard flasher that I have seen. and the bron goes back. but whzere is this interuptinion in the diagramm. maybe there is the mistake.
It must be the brown one. because normal everything works and this is the only thing that is not working
Another Idea is: The best idea would be if you tell me how it is possible to disconnect the turn signals from the break lights. because I am not allowed to use the original american way in Germany.
I have to youse the tail parking lights for the turning signal.
It would be very great if yu tell me which cable i need to change to have the tail parking lights for the turning signal.Last edited by Player87; 05-30-2007 at 11:00 AM.
05-30-2007, 01:18 PM #7
you should be able to run to the hardware store and get a flasher wire that you could splice into your wires right before your housing
05-30-2007, 11:49 PM #8Junior Member
- May 2007
OK Guys THX a lot for your Help. It works now.
This night I got a wonderful idea. why don't change the hazard and the turn assembly. 10 minutes ago I did this, and now everything works fine.
Now I have my other querstion how can I split the turn signal from the brake light, because I want to use my tail parking lights for the turn signals.
You know which wires I have to combine?
THX
05-31-2007, 06:37 PM #9Junior Member
- Sep 2006
- s.e. ma
primer- 65 nova
hello
each tail lamp has 3 wires left is yellow,brown and brack
right is green,brown and black
brown =park lamps black=ground(earth) yellow=left turn/brake
green =right turn/brake
from the brake switch you will see a light blue wire which sends power to the high mounted brake lamp in your spoiler(air foil,wing) disconnect the light blue wire from the hazard/turn switch now find the light blue wire near your high mount brake lamp spice in 4 wires run 2 to the left tail lamps and 2 to the right. now cut the 2 yellows on the left bulbs and connect the light blues do the same to the greens on the right side bulbs now the red taillamps will be park and brake only
I bet you won't click just once...
By allbaugh_04 in forum Almost Anything GoesReplies: 10Last Post: 09-09-2013, 02:45 AM -
Tranny click - need help
By 2kSSnTX in forum Automatic TransmissionReplies: 10Last Post: 07-14-2008, 04:46 AM -
Click It's So Awesome!!!
By '99 SLP#24 in forum Almost Anything GoesReplies: 23Last Post: 10-26-2007, 06:09 PM -
Click
By FuxOnTheFirstDate in forum Almost Anything GoesReplies: 9Last Post: 07-17-2006, 09:24 AM -
Click Here To See
By OneBadZ in forum Appearance SectionReplies: 13Last Post: 11-22-2005, 12:16 PM
