Results 1 to 11 of 11
Thread: Tranny click - need help
07-07-2008, 08:28 AM #1Junior Member
- texas
artic white- 2000 SS LS1
Hi all,
I have 2000 SS camaro with 102k miles, automatic transmission. I've never had it worked on other than regular maintenance.
I've recently noticed some clicking coming from under the car. At first I thought the rear end or u-joint, but i think i've narrowed it down to the trans area.
Here is whats going on: If i go from reverse to park or vise versa, the car will click, once.(sometimes it doesn't click but its becoming more frequent) Also if I'm at a stop it will sometimes click.(always just one click)Sometimes if I ease from a stop then get on the throttle it will click, and when i let off it will click again.
I don't know much about transmissions so any help would be great.
07-07-2008, 09:06 AM #2Junior Member
- texas
I would also like to say that when shifting into second it will click if under a good load. I don't think 2nd gear has anything to do with it but I believe its the force or stress thats causing the click.
Maybe a lose mount or mounting bolt?
07-07-2008, 09:11 AM #3Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
i'm havin a similar issue. . . had the car on the lift this w/e and couldnt really narrow it down yet. i had my tranny rebuilt about 10,000 miles ago and have had a very slight leak at the tail of the tranny since. i believe the issue is there, in tail . . . hope someone has more input because we could both have the same cause.
07-07-2008, 09:18 AM #4Junior Member
- texas
Now that you mention it, mine had some fluid at the tail end of tranny. I didn't think much of it considering the miles and I previously had a leaky oil filter. I'll double check when i can to see what type of fluid it is.
07-07-2008, 09:29 AM #5Senior Member
- Oct 2007
- Muncie, IN
ya i would . . . im gonna have my dads friend, who is really good with driveshafts and trannies, look at it and see what he thinks. id hate to go thru the pain in the ass of pullin the tail off the tranny, and then it only be something driveshaft related.
07-08-2008, 05:15 AM #6Senior Member
- Oct 2007
- Muncie, IN
bump. . . anyone have a similar issue?
07-08-2008, 03:24 PM #7Senior Member
- Oct 2007
- Muncie, IN
talked to my brother in law today and he said his 96 ss impala did the same thing. but never had any further problems with it. its gotta be a sorda common "wear" problem
07-11-2008, 02:18 PM #8Junior Member
- texas
I brought mine to a tranny shop today for a checkup. They notice that the bushing in the rear housing is lose which prolly has something to do with the fluid leak in that area, but not sure if thats causing the click. It could possible be a U-joint but we wont know untill they take the drive shaft off and move the u-joints around by hand.
GULLETT17, when you had ur tranny rebuild, did they rebuild the rear housing also? Is there slack in yours where the forward yoke goes into the rear housing?
07-13-2008, 04:59 PM #9
07-13-2008, 05:09 PM #10Junior Member
- texas
Well mine has maybe 1/8" of play in it. Wednesday they will replace the bushings in the rear housing and while the shaft is off i'll get'm to replace the u-joints too, they are cheap enough. I'll keep you posted on how it turns out.
07-14-2008, 04:46 AM #11
I bet you won't click just once...
By allbaugh_04 in forum Almost Anything GoesReplies: 10Last Post: 09-09-2013, 02:45 AM -
Hazard Problem (Click, Click, Click) but no light
By Player87 in forum General HelpReplies: 8Last Post: 05-31-2007, 06:37 PM -
Click
By FuxOnTheFirstDate in forum Almost Anything GoesReplies: 9Last Post: 07-17-2006, 09:24 AM -
TBI Bashers Click Here
By bww3588 in forum General HelpReplies: 0Last Post: 12-05-2005, 07:07 PM -
Click Here To See
By OneBadZ in forum Appearance SectionReplies: 13Last Post: 11-22-2005, 12:16 PM
