    socal
    LS! to Muncie 4 Speed
    Is it possible to mate an 01 LS1 to a Muncie with a S/B bell housing and Z- bar peddle?
    Thanks,
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    Just curious, but why would you want to do this? Retro-fitting an older car?
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    I agree why do it?? dont you want 5th and 6th gears??
    Feb 2007
    austin
    Black/Black
    '00 Firebird WS6 T/A
    his name is 71fbodyfan so i'm assuming he has a 71 fbody with a 4 speed muncie and wants to put an ls series engine in it.
    socal
    I am putting a 71 together from a bare shell, needless to say the console replacement and transmission rebuild were pricey. If I can still use both with a gen III up front, monies could be directed to other areas (dash, RS conversion, ect.) The only benefit of the Muncie is it fits the console. Pace lists a bellhousing for gen III to older trans for under $300.00. Basically, I am trying figure out the best bang for the buck.
    Thanks
    Rockford, IL
    Quote Originally Posted by 71FbodyFan View Post
    Thanks
    fresh paint? looks frickin amazing man. would u mind postin some more pics of that? looks really nice
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    With the correct bellhousing and clutch for the Muncie input shaft, I really don't see why it wouldn't work. The LS1 uses the same bellhousing bolt pattern on the back of the transmission as a traditional small block Chevy, so the old style bellhousing should bolt right up to it.
  1. '72 Z-28 with ZZ4 crate motor and Muncie 4-speed
    By 02ultraZ in forum Vehicles For Sale / Trade
    Last Post: 10-08-2010, 07:51 PM
  2. Help: Need in on LT1 to Muncie 20 4-speed tranny swap
    By jcsgarage in forum Drivetrain
    Last Post: 05-03-2010, 01:41 PM
  3. Muncie Four Speed Transmission Makeover - Pontiac
    Last Post: 10-14-2008, 09:50 AM
  4. Question: LS to Muncie or Tremec 5 sp
    By blackdiamondmotorspo in forum Manual Transmission
    Last Post: 04-25-2008, 12:14 PM
  5. muncie to ls1
    By everett in forum Drivetrain
    Last Post: 05-01-2007, 10:59 AM
