Thread: 408 piston questions
08-23-2007, 08:22 AM #1
i'm looking at getting pistons for my iron lq9 stroker, boring it .030 over, is -2cc valve reliefs gonna be enough for the l92 heads? i was told no,what should i go with when i order my pistons since i plan on doing it in the next few days.
i want a compression ratio thats gonna be ok to run on 94 octane so is 11:1 too much, cause i've seen 4 cylinders with 10.5 stock running pump gas
i also thought of boring the block .060 over for more cubes but not 100% sure yet if i should
08-25-2007, 05:23 AM #2
going .060 over will bring you to a 415. if you ever need to rebuild the motor, you won't be able to bore the block again.
i use the wiseco k394a3 pistons with a -8cc dish. with my heads at 62cc, i'm at 11.3:1 compression and run 91 octane everyday.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
08-25-2007, 06:06 AM #3
08-25-2007, 10:34 AM #4Slow'er'Ass
- Thornton, CO
Mahle's.
08-25-2007, 06:03 PM #5
piston slap or not
By acews6 in forum General HelpReplies: 2Last Post: 11-05-2014, 10:07 AM -
cracked a piston
By rumblebox in forum Internal EngineReplies: 9Last Post: 02-05-2009, 09:19 AM -
Piston Slap
By shlby123 in forum General HelpReplies: 10Last Post: 01-18-2007, 01:39 PM -
5.3L Piston?
By 99transamC/FIA in forum Internal EngineReplies: 0Last Post: 06-30-2006, 10:02 AM -
piston slap?
By wicked illusions in forum Camaro / SSReplies: 4Last Post: 05-28-2006, 05:27 PM
