Results 1 to 10 of 10
    V6 with WS6 wheels......
    victoria, tx - now camp pendleton, ca
    99 formula a4
    cracked a piston
    this is the result of being forced to run an engine hot after blowing a head gasket.
    i need an 5.7/6.0 shortblock or a 5.3 longblock asap.
    Sep 2008
    kansas city mo
    2000 camaro ss
    that sucks brother . sounds kinda like some of my luck..
    Billings,MT
    Sunset Orange Metalic
    2002 Firehawk
    Which cylinder is that?Just wondering because I broke a chunk out of #4
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    that's cylinder #3 as i can see the oil filter under the block.
    Orlando FL
    Red+White Top and Stripes
    2000TransAmConvertible A4
    DAMN! How can you see that in the pic?
    orlando, fl
    2014 camaro 2ss/rs
    look just under the headbolt hole to the right of the cracked piston.
    Orlando FL
    Well I see that but I still don't know how you can tell, the camera is at a bad angle, and you can only see 2 and a half cylinders.
    orlando, fl
    2014 camaro 2ss/rs
    hang on it's #5. stupid me. the last piston in the picture doesn't have the V water jacket. so that's the last piston. the oil filter is on the driver's side.
    Parma Heights, Ohio
    SOM
    99 Trans Am
    nothing a lil bondo and duct tape cant fix... what was the reason you were [I]forced[I] to run it hot? Just curious.
    i say take this opportunity to put a stroker in
    Member 99transamC/FIA's Avatar
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    I have a complete 5.3l if you need it. It's out of a 04' with less then a 1000 miles on it.
    Cheap $2000 O.B.O.
  1. Question: cracked
    By 383ls6 in forum Showcar and Detailing
    Last Post: 07-01-2012, 12:58 PM
  2. cracked rotor
    By LimeNine in forum Camaro / SS
    Last Post: 09-11-2010, 01:37 PM
  3. Help: Cracked oil pan.....
    By civenegas85 in forum GTO
    Last Post: 03-30-2010, 05:09 PM
  4. cracked rim
    By Train in forum Wheels and Tires
    Last Post: 02-01-2010, 08:09 AM
  5. 5.3L Piston?
    By 99transamC/FIA in forum Internal Engine
    Last Post: 06-30-2006, 10:02 AM
