Thread: Just did the hose mod...
11-06-2005, 08:59 AM #1Heavy Set Thin Guy
- MA
Quicksilver Metallic- 2005 Pontiac GTO
and I'm very happy with it. The car sits a solid inch lower than before. Handles great, no squeaks and it only took about an hour. Best $4 I've spent on the car!! One word of advice, put a little motor oil on the top part of the spring to allow the hose to slide on a little easier. I had a hell of a time at first but after I put the oil on it, it slid on like a bride on her wedding night...
11-06-2005, 02:06 PM #2Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Yeah same here great mod! Lowered me an inch on both sides too, no more tugboat look
11-06-2005, 02:16 PM #3
Tell me about the hose mod--what size hose? What kind? Abrasion resistant? Garden hose? Heater hose? Thanks in advance--
Bob
11-06-2005, 02:29 PM #4Senior Member
- Jul 2005
- Earth
3/8 inch Heater hose. I used 2 ft on each side to be safe, spray some WD-40 on the spring to get it to slide on easy
11-06-2005, 04:32 PM #5
Cool! Gonna do it tomorrow! Thanks Hurley 711!
Bowtie good! Blue oval not so good! Bob in the PRK
11-06-2005, 04:47 PM #6
11-07-2005, 02:48 AM #7Heavy Set Thin Guy
- MA
The mod lowers the rear of your car ~1 inch by removing the factory rubber isolator that is about 3" thick (I wasn't even thinking about the weigh savings either) and replacing it with heater hose. You wrap the top coil of the spring with it to keep the same value of the isolator without the bulky size. It takes about an hour to do, just be careful when you pull your springs out, it's a good idea to wrap a chain or something around them so it doesn't jump out at you if there's still a little pressure on it. I used a small piece of a 2x4 against the brake rotor and the bumpstop to lower each side but I still had something in there in case the spring wanted to come out on it's own. Highly recommended first mod!!
11-07-2005, 01:24 PM #8Senior Member
- Jul 2005
- Earth
weight savings?!?!?!
Dude those 2 lbs. will never be noticed good try though!!
11-07-2005, 01:31 PM #9
Just did it. Can of corn. Dropped the rear end 1 1/4 in. Took 1 1/2 hrs with beer drinking and snacks. Thanks for all the help, guys! This place rocks!
11-07-2005, 02:24 PM #10Heavy Set Thin Guy
- MA
Have you ever seen the list of things that people pull off their car to save weight? I'm sure someone has pulled the isolators and thought "sweet!! i'm gonna break 12 seconds this weekend now!". Not me though...
Originally Posted by Hurley711
Congrats Bowtie, you're bit by the bug now!!
11-07-2005, 04:22 PM #11Senior Member
- Jul 2005
- Earth
C'mon man I'm just teasing ya you know as well as I do 2 lbs. ain't doin nothin for ya. Rule of thumb is 100 lbs off shaves a tenth for you, so do the math for 2 lbs
11-08-2005, 03:17 AM #12Heavy Set Thin Guy
- MA
Sweet, then I'm gonna save .002 on my 1/4 times...
I know your bustin balls, that's okay, I am too. If weight were a concern for me, I'd drop a couple myself first.
Where does this hose go to?
By SiskMan in forum General HelpReplies: 7Last Post: 10-20-2014, 05:52 PM -
Question: what does this hose do?
By Ed Howell in forum DrivetrainReplies: 7Last Post: 03-01-2012, 04:21 PM -
PCV Hose
By pajeff02 in forum General HelpReplies: 21Last Post: 02-24-2010, 04:47 PM -
what is this hose?
By DemonSpeed in forum General HelpReplies: 3Last Post: 08-13-2008, 07:59 PM -
Where does this hose go?
By Isma98Z28SC in forum General HelpReplies: 1Last Post: 08-18-2007, 08:53 PM
