Thread: what does this hose do?
02-27-2012, 11:40 AM #1Junior Member
- Feb 2012
- Seaford, Delaware, United Stat
blue- 1998 trans am
ok long story straight i was installing my torque arm yesterday. when i was pulling the old one down there was rubber hose that was clipped to the old torque arm well not paying attention i pulled it out. it does on the top of the tranny? so my main question is it important and, what does it do?
02-27-2012, 11:45 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Sounds like the vent tube for the tranny
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
02-27-2012, 12:58 PM #3Junior Member
- Feb 2012
blue- 1998 trans am
is it important to reattach
02-27-2012, 04:52 PM #4Former Mopar Man
- Jun 2011
- Branchville, NJ
Not really important to reattach but if you blow some trans fluid it will leak on the trans and may hit the exhaust and catch fire. But that is the worst case.
02-27-2012, 06:49 PM #5
There is a white plastic thingy on top of the trans that it attaches to. Kind of hard to get at, but if you can I would plug it back in. This is what it looks like -- the open end kind of threw me but this is how it is supposed to look. The hose to the right of the plastic thingy goes to the transmission vent tube and the one to the left runs down the tunnel and clips to the torque arm. I zip tied my vent hose to the fuel and/or brake lines in the tunnel when I swapped out to a tunnel mount torque arm.
02-28-2012, 06:16 AM #6Junior Member
- Feb 2012
blue- 1998 trans am
ok thanks guys guess when i change my oil this weekend ill be playing where is waldo trying to find it and re attach it!!!
02-28-2012, 08:23 AM #7
It is right on top of the transmission. You should have enough slack to fish it to one side and then re-connect the hose. You can also use a floorjack to lower the transmission a bit to create more working space. Start by unsnapping the lid on your air cleaner so as not to put undue tension on it, then unbolt the transmission crossmember (4 bolts) and lower it a bit on the jack. Don't get too carried away with lowering it as you don't want to pinch or break anything at the back of the engine.
03-01-2012, 04:21 PM #8Senior Member
- Apr 2008
- Madison, WI
Where does this hose go to?
By SiskMan in forum General HelpReplies: 7Last Post: 10-20-2014, 05:52 PM -
PCV Hose
By pajeff02 in forum General HelpReplies: 21Last Post: 02-24-2010, 04:47 PM -
what is this hose?
By DemonSpeed in forum General HelpReplies: 3Last Post: 08-13-2008, 07:59 PM -
Where does this hose go?
By Isma98Z28SC in forum General HelpReplies: 1Last Post: 08-18-2007, 08:53 PM -
Just did the hose mod...
By t/as&dds in forum Suspension and HandlingReplies: 11Last Post: 11-08-2005, 03:17 AM
