Results 1 to 18 of 18
Thread: Battery Tray/Hold Down Question
08-19-2007, 12:38 PM #1
I'm sure anybody can help me with this.
How does the battery get held down from the factory? I have the plastic tray it sits on, and then I have that wedge looking thing that bolts to the tray behind the battery. Am I missing anything? That thing really doesn't hold the battery well at all, it still slides and I can actually lift it out. Is this common or what do I need? Thanks!
08-19-2007, 12:51 PM #2
I have an 02 convertible with the same exact problem. Fist time I went to the track the tech inspector pointed this factory flaw out to me & wasn't going to let me run. Then when he saw that none of the late model Camaro's had a hold down brace from the factory he decided to let us all race anyway.
08-19-2007, 12:54 PM #3
So thats the factory way huh? Nice...
Anybody find an aftermarket hold down or something thats better?
08-19-2007, 03:50 PM #4
08-19-2007, 03:51 PM #5
ive seen a billet one before but cant find it for you
08-19-2007, 03:55 PM #6
the battery tray has a lip opposite of the clamp. the battery slides under it. mine broke at the track one day when launching. the battery flips over and the positive cable grounds against the accumulator bracket.
two things to fix this. get another factory battery tray, or get this, which will be cheaper and not break.
http://www.yearone.com/serverfiles/p...G&hid=G14AM907
08-19-2007, 06:35 PM #7
08-19-2007, 06:40 PM #8
is that adjustobol or will work with the otima?
08-20-2007, 02:00 PM #9
08-20-2007, 02:30 PM #10
08-20-2007, 04:23 PM #11
just checking casue i know my optima is a wierd 6 pack design
06-11-2008, 04:37 PM #12Junior Member
- May 2008
- denison,tx
Thanks I Just Broke Mine Last Week ,and Waiting On A New One! The Inside Lip Broken And Turned Sideways Kinda,
2000 NHRA TRANS AM M6 228/228 .588/.588 114+2 COMP CAM! RHS STAGE1 PORTED AND POLISHED HEADS.
06-11-2008, 04:38 PM #13Junior Member
- May 2008
- denison,tx
Ive Got A Reptop Too
06-11-2008, 04:49 PM #14Exalted Cyclops
- Feb 2007
- San Diego, CA
The battery hold down is also a part of the coolant recovery tank. To replace the part of the hold down that breaks (the lip that is molded in at the front) you have to replace the tank.
The wedge goes in the back and has a bolt that threads thru into a boss molded in the tank.
06-11-2008, 06:11 PM #15
02-12-2009, 01:38 AM #16Impounded
- Oct 2007
- Beaver Dam KY
You my friend are the SHIT!
Bump because I NEED to do this soon.
02-12-2009, 03:12 AM #17Senior Member
- Nov 2006
- Indianapolis
That's how I found out mine was broken, the tech inspector at the track. Not the current car, my old one, the '98 broke its' hold down. I check it all the time, if it breaks in Too Fast I'll get the one that goes over the top from Year One.
02-13-2009, 09:57 PM #18UberTapping Friction Pimp
- Mar 2007
- Omar's Tittie Taverna & Grill, Deh Rawod
18D Cock Diesel- 1999 Z28; 98 SS #2043 RIP
Yeah so I got the bungee thing happening in mine due to the oversized Optima Red Top. Well, at least its a red one like the car.
Thanks for the idea. I will fab a custom one for my car."I am the executioner. When a crime is committed and the exalted state does not take vengeance nor move to punish, then comes time for the executioner to declare himself. I have waited long enough. The criminals are hereby sentenced to death. By fire. By earth. By water."
Battery Hold Down - Hold Down Hold Up
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-06-2013, 06:20 PM -
Battery Tray
By Sweet Chops in forum Parts Wanted / TradeReplies: 2Last Post: 01-18-2011, 11:37 AM -
Battery tray for 99 T/A
By Piranhaz in forum Parts Wanted / TradeReplies: 9Last Post: 02-01-2010, 02:40 PM -
Wanted: Battery Tray
By 2MuchFun in forum Parts Wanted / TradeReplies: 4Last Post: 06-17-2008, 02:04 PM -
Wanted: Battery Tray, SLP Lid, & more
By 2MuchFun in forum Parts Wanted / TradeReplies: 0Last Post: 06-10-2008, 08:43 AM
