Results 1 to 10 of 10
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Battery tray for 99 T/A
    Need the plastic battery tray base for my 99 T/A. The back brace that the battery tucks into is broke on mine and doesn't hold the battery tight :-(
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    its actualy attached to the over flow bottle
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    as one peice
    Canada eh
    99 TA
    they are cheap from the dealer... i got one for under 60 bucks (tray and overflow bottle)
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Year one carries the over flow tank. I used this instead;
    http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
    SoDak
    White over Red
    1991 Suburban
    7 (100%)
    I would have to look out there and see what I have but I think I have a couple of these left from last year. I know I have some....it's just a matter if they look good enough for me to sell. If you're interested I can take a picture of a couple and let you pick one.
    http://www.ls1.com/forums/showthread...t=battery+hold
    SoDak
    White over Red
    1991 Suburban
    This is way better than using the factory setup to hold your battery in place. I took an old serpentine belt and use it between my bracket and the battery to keep it form rubbing. Plus it gives a tighter fit.
    7 (100%)
    Quote Originally Posted by thearborbarber View Post
    I started including a little piece of foam that has adhesive on one side of it with these. I've ran mine for a few years now without the foam and honestly it holds the battery so tight that I don't see rubbing being an issue ( at least it hasn't on mine). After making a few of these last year I decided if I was going to do any new ones I would make them out of aluminum because it's just easier to work with and mine has a few little rust spots on it so aluminum wouldn't rust either.
    That being said I have 1 left out there made out of steel....if the original poster is interested in it I'll sell it to you for $11 dollars shipped and paypal'd. The dollar just helps cover the paypal fees.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Instead of foam you could just pick up some rubber electrical tape. Nice and thin too.
  1. Battery Tray
    By Sweet Chops in forum Parts Wanted / Trade
    Last Post: 01-18-2011, 11:37 AM
  2. Wanted: Battery Tray
    By 2MuchFun in forum Parts Wanted / Trade
    Last Post: 06-17-2008, 02:04 PM
  3. Wanted: Battery Tray, SLP Lid, & more
    Last Post: 06-10-2008, 08:43 AM
  4. Need Battery Tray!
    By sic2001 in forum Parts Wanted / Trade
    Last Post: 08-06-2007, 07:18 PM
  5. need battery tray/holdown
    By andy670ho in forum Parts Wanted / Trade
    Last Post: 05-08-2007, 07:57 AM
