Results 1 to 20 of 28
Thread: spark plug
    Member SuPeRmAn23's Avatar
    Mission,TX
    2002 camaro z-28
    spark plug
    can i change the spark plugs myself i hear its pretty hard to do
    Aug 2000
    Indy
    patients thats all
    Mission,TX
    2002 camaro z-28
    o ok...they are charging my 120 for a tune up...is that about right?
    Aug 2000
    Indy
    not bad,
    I wonder if they will replace plug # 8, you should mark it to make sure it is replaced !
    somewhere
    Quote Originally Posted by Danger731 View Post
    not bad,
    Good idea
    Senior Member splitfinger09's Avatar
    Bartlesville, Oklahoma, United
    Bright Rally Red
    2000 Camaro SS #5075 M6
    Do it yourself, I just changed the plugs and wires in mine the other day and it wasnt to hard at all. Drivers side only takes like 30 min, the passenger side is a little harder, just take your time and you'll get it. Plus you get the satisfaction of doing it yourself.
    Mission,TX
    2002 camaro z-28
    hmm i was thinking about that but im not to sure...maybe i can ask one of my friends to help me ...how about the egr tube and A.I.R delete or whatever...can i do that too....and the fuel filter
    Bright Rally Red
    Quote Originally Posted by SuPeRmAn23 View Post
    Yeah another set of hands is always nice to have. If you do the EGR/AIR delete you have to have the block off plates and the plug for the intake manifold. Then you have to have the codes tuned out or you will have an annoying SES light. Another way to do it w/out the block off plates and the plug is to do "race style" headers and an LS6 intake, neither have provisions for the ERG/AIR. Fuel filter is no problem, 15 min max. Go to install university they have a great write up on it. Good luck.
    I just noticed you have a 2002, if so you do not have EGR and you already have the LS6 intake.
    Mission,TX
    2002 camaro z-28
    i have an ls6 intake...
    Mission,TX
    2002 camaro z-28
    i think there going to charge me another 120 to get it tuned
    Bright Rally Red
    Thats not to bad for a tune. To get the AIR code turned off its usually around $50-$60.
    Mission,TX
    2002 camaro z-28
    well its going to be 240 plus parts....how much do u think it will be for plugs wires fuel filter?
    Bright Rally Red
    For MSD wires and AC/Delco Iridium plugs your looking at $120
    Fuel filter $8-$10
    Mission,TX
    2002 camaro z-28
    so like id just say 400? ...
    Mission,TX
    2002 camaro z-28
    and im not looking for msd....i want stock gm wires...and tr55
    Bright Rally Red
    Thats $400 including labor. Its really not that hard at all I think you can tackle it yourself man. Save the cash and go buy the tools you will need. Why do you want stock GM wires? The tr55 are alot cheaper than the AC/Delco, less than $2 a plug, but you will have to change them again in like 20K miles.
    Mission,TX
    2002 camaro z-28
    well maybe i will get some better wires...i hear the other wires dont make too much of a difference and not worth the money...
    Bright Rally Red
    Well I dont know how much the stock GM wires are, but they are "stock LS1 6 in. - 351 ohms" The MSD wires are around 40-50 ohms and around $60.
    Mission,TX
    2002 camaro z-28
    well ill just see what happen this coming sat..then im also getting my stock exhaust cut off right in the middle
  1. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  2. spark plug w/ oil all over it...HELP!!!
    By L3THAL_Z28 in forum Internal Engine
    Last Post: 10-25-2007, 11:38 AM
  3. Spark Plug Gap
    By slpgto2004 in forum GTO
    Last Post: 10-05-2007, 04:58 AM
  4. Spark plug wire and plug!
    By RYDER661 in forum General Help
    Last Post: 03-13-2006, 09:01 PM
