    Waco Ky.
    2001 SS #3504
    Question Rattling, pinging noise in engine
    I have an 01 SS with 33,000 miles it has an awfull rattling noise around 2500 and up RPM. My first thought was bad gas. well after a few diferent fill ups from other gas stations it still rattles. I've even tried Octane booster with no change. it isn't throwing any codes, so does anyone have any suggestions? Also it doesn't have to be under a load to cause this rattle. It's holding good oil PSI so i wouldn't think it's a bearing failure.
    Senior Member 02ultraZ's Avatar
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Were you using premium fuel from the pump too?
    Member GNICTRY's Avatar
    Virginia
    2000 Trans Am WS6 Ram Air
    does it keep doing it or does it only do it within 2500 rpm range...I have the same issue...i think...it sounds kinda like coins or heat sheild rattle...i replaced my belts and it went away but came back once they were broke in...I think it might be a pulley
    Waco Ky.
    2001 SS #3504
    yes 93 octane. it rattles on up through all the rpm range. what pully was rattling on yours? it has been dyno tuned could this be the culprate?
    Quote Originally Posted by casperss View Post
    If they maxed out your timing for some reason...yes.
    Waco Ky.
    2001 SS #3504
    the tune was done before i bought it so whatever was done to it i'm unsure. it was done with hp tuner. does anyone know a shop around ky. that uses this setup?
  1. Question: pinging noise at high rpm
    By 02fbody35th in forum Camaro / SS
    Last Post: 12-07-2008, 05:49 PM
  2. Rattling noise, is it a cat problem????????
    By JwMonE99 in forum General Help
    Last Post: 11-16-2006, 05:21 PM
  3. knocking rattling noise
    By camarostripes96 in forum Internal Engine
    Last Post: 09-19-2006, 06:55 PM
  4. Pinging noise from underneath car
    By Drks1de in forum General Help
    Last Post: 07-01-2006, 09:10 AM
  5. NOISE!!!! So Much Rattling!!!
    By boone94 in forum Firebird / WS6
    Last Post: 12-29-2005, 05:55 AM
