Results 1 to 11 of 11
Thread: runnin hotter
    Drive it like its stolen gillahoon's Avatar
    Carbondale, Pa
    runnin hotter
    I just put a lid and did the TB bypass on my car and now it runs hotter is this normal. Or is something eles going on never ran this hot before. its not over heating use to run 160 now runs 210.
    Justin
    Ann Arbor
    2002 WS6
    Whoa. I cant believe the TB bypass made it run hotter,Its supposed to do the exact opposite Check to make sure you don't have a coolant leak. I'm sure its not the air lid. This is good to know since I was thinking about doing the Tb bypass. Sorry I cant offer an explanation on why this happened.
    Bragg NC
    Met. Sunset Orange
    01 SS
    The tb bypass mod will not make it run hotter, all it does is bypass the tb, On a stock car it runs through the throttle body to help heat up the incoming air on cold starts.
    What mods are done? What temp thermostat do you have? Air in the system?
    J
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    My money's on air in the system
    Justin
    Ann Arbor
    2002 WS6
    Hey Gillahoon, do you have the aftermarket 160 degree thermostat installed??
    Carbondale, Pa
    as far as i know its still the stocker
    STL
    RED
    2001 CAMARO Z
    air in your line
    Carbondale, Pa
    how do u get the air out
    open the cap ( car cold) and run it a while until the coolant starts circulating and then top off if need be. Also, unless your fans and have been adjusted and you're running a 160 stat I don't think your old temp ran at 160. The stock stat doesn't even open up that low. I know with a 160 stat and my fans adjusted I run in the 170-180 range but some of that is because I have a tranny cooler mounted in front of the radiator.
    Justin
    Ann Arbor
    2002 WS6
    I was also wondering how his car could be runninng at 160 with the stock thermostat.
    Anways, do you notice any differences with the 160 after market thermostat? Is it really worth the trouble? and how difficult is it to install?
    Jr.
    d
    2002 z28
    out of left field but do you have your air deflector under front bumper. not sure if the temps would go that high if not installed but like i said left field
  1. Which is hotter?
    By onetroubledguy in forum Firebird / WS6
    Last Post: 04-13-2009, 02:41 PM
  2. Running Hotter After Maintenance Work?
    By silverbird22 in forum General Help
    Last Post: 04-07-2008, 03:26 AM
  3. Hotter or Colder T-Stat ??
    By b.lee in forum Internal Engine
    Last Post: 07-12-2007, 07:19 AM
  4. Car Running Hotter
    By Ghostdogg in forum General Help
    Last Post: 01-01-2006, 07:08 AM
  5. have to get hotter o2 sensors???
    By tank99_999 in forum General Help
    Last Post: 10-08-2005, 12:04 PM
