Thread: have to get hotter o2 sensors???
10-03-2005, 08:08 PM #1tank99_999Guest
I put long tube headders on my 2001 ss and no cats and i am wondering dose the ses light do ne thing to the car. And i had someone delete the o2 sensors with hp tuning and he said i need corvette rear o2 sensors becouse mine do not get hot enough and the light came back on,also i have a A/f gadge how do i hook it up with out cutting the o2 sensor wire???
10-04-2005, 12:56 PM #2KatechGuest
Originally Posted by tank99_999
You need O2 sensor simulators for the downstream O2 sensors. You can connect the AF gauge by tapping the signal wire of the upstream O2 sensor with a wire tap.
10-04-2005, 01:54 PM #3tank99_999Guest
downstream O2 sensors??upstream O2 sensor??need help
10-04-2005, 02:02 PM #4
The 02 sensor that's after the header collector. You have 4 02 sensors. The pre cat )2 sensors you'll find on the header collectors usually. The aft cat sensors are after the Cat convertors on the Y pipe. With deleted rear 02 sensors you usually need )2 sims if not deleted by a tuner. As far as a hotter 02 sensor for your long tubes, Look into a set of Denso's
10-08-2005, 12:04 PM #5tank99_999Guest
i had them taken off with hp tuneing and my light still came on
Which is hotter?
By onetroubledguy in forum Firebird / WS6Replies: 39Last Post: 04-13-2009, 02:41 PM -
Running Hotter After Maintenance Work?
By silverbird22 in forum General HelpReplies: 16Last Post: 04-07-2008, 03:26 AM -
runnin hotter
By gillahoon in forum General HelpReplies: 10Last Post: 08-15-2007, 02:46 PM -
Hotter or Colder T-Stat ??
By b.lee in forum Internal EngineReplies: 1Last Post: 07-12-2007, 07:19 AM -
Car Running Hotter
By Ghostdogg in forum General HelpReplies: 1Last Post: 01-01-2006, 07:08 AM
