Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    NW Chitown
    2002 WS6
    Dyno #'s w/HSW 150 wet... runs RICH
    Hey all-
    Went to the dyno yesterday... 101* and 52% humidity...
    My NA pull made 316hp 323tq. The A/F ratio is a little fat, but its a nice flat line and the car ran well there - any leaner and it looses power.
    My N2O pull made 394hp 486tq... you'll notice no A/F chart on this sheet... because it ran SUPER fat. So fat indeed that the moment the nitrous hit, the A/F #'s fell below 10 and the machine couldn't chart them! With 150HP jets installed, I only increased 78HP and 163TQ.
    Bottle pressure was at 1000psi and it was 101*F in the dyno building.
    With the increased bottle pressure, I'd expect to see it a little lean... not so damn rich that it bogs down the car when the n2o hits (still strong, but I'm leaving 20-30hp on the table I'd bet.)
    I need to jet the fuel down a bit since the A/F is linear and fairly close to correct NA... but falls thru the floor and goes FAT on the juice. Question is, how far do I go? I'm currently running n20=.062 fuel=.034. Wish I could have re-jetted it on the dyno, but that wasn't an option unfortunately. I still dont have a wideband either.
    I'm uploading short vids of each pull to putfile now, I'll post them a bit later.
    -Eagle
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
    Aug 2000
    Indy
    Is this a newer HSW kit ?
    NW Chitown
    2002 WS6
    Yes, I bought it in May? of this year. Its the sudden impact wet kit.
    NA pull vid:
    http://media.putfile.com/NA-Dyno-Pull---AFM-Aug-07
    N2O pull vid (listen for the bog right when the window switch goes on):
    http://media.putfile.com/NA-Dyno-Pull-AFM-Aug-07
    -Eagle
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if it's under 10:1, i would go down to .031 jet. most companies use 62/32 as a 150 shot.
    NW Chitown
    2002 WS6
    Its definitely under 10... the meter just flat lined at 10 and sat there the entire pull...
    I have a .031 jet handy... I'd want to scan against it tho... its the jet thats supposed to be used for the 125 shot according to the card. What O2 voltage should I expect? Still 890s?
    orlando, fl
    2014 camaro 2ss/rs
    950-980ish
    NW Chitown
    2002 WS6
    Roger that! Thx mrr!
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Ouch. You should have way more in it than 78hp. I gained 98.2rwhp from a 100-shot (Dyno Tune Kit).
    NW Chitown
    2002 WS6
    I did get quite a bit of torque tho... I'm always looking for the silver lining...
    Aug 2000
    Indy
    Fix that A/F, Matt says the new kits are rated RWHP. You got a 50 % loss.
    NW Chitown
    2002 WS6
    Ya I know it, thats my problem! I'm hoping Matt will reply here...
    d
    2002 z28
    isnt torque the one that really matters thoe, nut high 70's hp, should be more.
    orlando, fl
    2014 camaro 2ss/rs
    the hp number is a joke. i have been as low as 91 rwhp on a 150, but i finally got it figured out.
    d
    2002 z28
    is that a new ride for you MRR23 thats on your sig??
    orlando, fl
    2014 camaro 2ss/rs
    yep. i bought badbluebird car.
    NW Chitown
    2002 WS6
    Congrats on the new ride mrr! Whats the plans for that one?
    orlando, fl
    2014 camaro 2ss/rs
    want a full out race car. going to gut it out and build a 454 LSX motor for it. always liked the maui blue.
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Why not '455' for Trans-Am tradition??
    486/438
    10.68/127 N/A
    orlando, fl
    2014 camaro 2ss/rs
    don't feel like honing out the new LSX block for 1 cubic inch.
    NW Chitown
    2002 WS6
    lmao @ 1 cubic inch.
  1. Question: Cleaned Out My Catalytic Converters now runs way too rich???
    By Rogernstjoe in forum Firebird / WS6
    Last Post: 02-09-2011, 08:38 AM
  2. 1 bank runs rich
    By anuka in forum General Help
    Last Post: 03-05-2009, 03:20 PM
  3. Running Rich AFR, anybody else with Dyno numbers?
    By nomorefords in forum Camaro / SS
    Last Post: 09-26-2007, 10:07 AM
  4. my last dyno runs
    By mrr23 in forum Dyno Information
    Last Post: 09-30-2006, 01:23 PM
  5. Engine runs rough, idles rough, runs rich
    By skintox in forum General Help
    Last Post: 08-22-2006, 03:31 PM
