    Junior Member KIXASS's Avatar
    MARYLAND
    Grille removal question
    What do you use (screwdriver?) to pop out the grille? I know there is 6 mounting tabs, but I'm unsure of the process to remove. I don't want to pry and break something if that is not how it is done. Can someone explain the process?
    THANKS!!
    DFW
    '18 CTS-V
    '13 ZL1
    i just released the tabs on the left and right sides, took a good hold of it and ripped it the "F" off...
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    x2... It's the easiest way.
    with a LS1 2MuchFun's Avatar
    Dayton, Ohio
    2005 Cadillac CTS-V
    i used side cutters and nipped the tabs off....but i was trashing the stock grill anyway...
    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    i used side cutters also when i took out mine
    Junior Member TAT MAN's Avatar
    Aug 2006
    At the end of I-75
    2001 Z28
    I just grabbed it and pulled one at a time. worked good. but is was butt puckering, worrying about ripping the bumpercover.
    No probs, just pull
  1. SLP SS Grille Question?
    By detsgt696 in forum Camaro / SS
    Last Post: 11-29-2007, 09:23 PM
  2. Grille Removal?
    By bluefields88 in forum Camaro / SS
    Last Post: 07-23-2007, 07:21 PM
  3. Stock Camaro Grille Removal?
    By Sunset T/A in forum Appearance Section
    Last Post: 02-13-2007, 07:16 PM
  4. Wanted : wings west grille or RKSport grille
    By z28_81 in forum Parts Wanted / Trade
    Last Post: 03-07-2006, 03:23 PM
  5. Front Grille removal and installation help
    By The Rookie in forum General Help
    Last Post: 11-29-2005, 05:52 AM
