Results 1 to 20 of 22
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Stock Camaro Grille Removal?
    Need tips on how to get the stock grille out without damaging the front nose. This is on a 4th generation Camaro. Thanks.
    Member Z27's Avatar
    Northern KY
    Green Red Black
    71 SS 00 SS 06 Impy SS
    I watched a couple of club members pop one out in a parking lot one night without using any tools. They just flexed it a bit to free up the tabs. It leaves a lot of holes that look out of place.
    Member graphicsgod's Avatar
    Orlando, Fl.
    1999 Chevy Camaro
    Quote Originally Posted by sunsetta
    It's a real pain in the ass!! You have to pop out one of the sides. Then you can access the four back ones that didn't come out without force. I used a saw blade and just worked each one till they all came off and freed the plastic from the car. It's a real pain in the ass, but with patience and enough force, they will come off.
    Rob
    R.I.P. LS1 LS1Power06's Avatar
    817, Texas
    03 Terminator
    Quote Originally Posted by graphicsgod
    Rob
    yep exactly how i did it. i also put a little touch up paint over the holes left the the license plate bracket. doesnt match perfectly but makes it not so noticable.
    RyAn
    Orlando, Fl.
    1999 Chevy Camaro
    Quote Originally Posted by LS1Power06
    RyAn
    Awwe damn! And I just made this crappy image in paintbrush to illistrate .
    Oh well, good to hear you got it off.
    Rob
    Aug 2000
    Indy
    hey thats an awsome go-by, needs a spot in archives !, Ed ?
    Drive it like ya stole it sills1's Avatar
    San Diego, California
    The safest way to take the grill is to remove the entire front facia. I did it in about an hour and it gave me the opportunity to clean up the car a bit more. You wouldn't believe how much crap accumulates under all that plastic.
    Member scooley's Avatar
    Cameron,Texas
    2001 Trans Am
    grill replacement
    When I got my new 35th SS, I ordered a SLP grill. The dealership installed it. I had the option of spending a LOT of money to remove the entire front clip to "save" the original grill, or have them cut the clips. They cut it off. Now the original grill makes a pretty cool piece of garage art.
    Member raysz28's Avatar
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    I have taken the grill most of the way off, but I wasnt sure how to get the three clips at the top. I did not want to break them off just yet. is there anymore details about how to remove this without breaking it? or is it just easier to break it?
    Thanks
    Ray
    98 Ticket Red Z28
    Mods:
    Front/rear sway bars, poly bushings all around, Bilstein Shocks, Centerforce Dual Friction Clutch, Pacesetter LT's, 2.5" Custom True Duals over the axle with Magnaflow mufflers, Shortened Pro 5.0 shifter, TurnOne PS pump.
    Orlando, Fl.
    1999 Chevy Camaro
    Quote Originally Posted by raysz28
    Thanks
    Ray
    I tried to remove them without breaking them but I don't think it's possible without taking the front off . So I just took a steak knife and hacked each one off one at a time.
    Rob
    Member mavrikZ's Avatar
    Logan, Ut
    2001 Trans Am
    Left hand in left vents. Right hand in right vents. Pull. Easy. No scratches. Done. Paint in CAMARO indentions. Drink a coldbeer and admire.
    Skiatook, ok
    Blue
    1998 z28
    I just pulled both side clips out and slowly peeled on side till it looked as though I was about to actually rip the plastic. Then POP , POP done .
    Compulsive F bomb dropper sgt0704's Avatar
    yuma arizona
    1998 Z28
    so then the "undergrille' looks like sills1? that's cool..
    SS-EIAN SSNAKEATER23's Avatar
    CHICAGO
    SILVER
    1999 CAMARO SS
    i pulled my grille off last nite, and it was a bitch!!!!!! at least the top clips were. the sides were nice and easy just pull eaisly and they popped out.
    For the top 3 i used a saw to get thru all excess crap, and then i used a pair of vice grips and gentley tried to pull and then one side of the paint spidered a bit. But i got throught it in a bout an hour, with plenty of frustration.
    Frustration + car = mistakes so be careful and take your time.
    Whisper Lid/SLP HarmonicBalancer/MAFTranslator/DiabloTuner A-Pillar Gauges (Aem Uego A/F,Trans Temp, D-Pic)Magnaflow CB w/CME Tips/ Eibach Pro Kit/ Brembo Cross Drilled/Slotted Rotors/ H.I.D.Kit
    CHICAGO
    SILVER
    1999 CAMARO SS
    i was also thinking if you get thru all the excess crap and all thats left are the top 3 clips can a small drill bit be used to drill thru the plastic, and possibly make this whole process eaiser?
    let me know what you guys think
    BIGRED Z
    Guest
    Just pull it off, no cutting, drilling etc required. On mine at least, it remained intact and does indeed make for some fine garage art!
    Lori
    jersey
    98 M6 Z28
    If there any way to take the grill off and still keep your license plate??
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    I have seen people mount the plate on the air dam under the car, but i dont know what the cops think about that location.
    Any other suggestions?
    Member camarolvr69's Avatar
    Woodbridge, VA
    1997 camaro z28
    Quote Originally Posted by SSNAKEATER23 View Post
    so is this the same procedure for the lt1 grill??
    baden pa
    Good luck ! I was in the same boat last summer when i was putting on my 35th anv SS SLP one and it is just like what these guys are telling you. I opted for the grip tight and pull method and yep, the stock tabs got messed up,but i didnt care because after receiving my SLP one in the mail i knew right then and there that the stock one was HISTORY!
  1. Wanted: Stock 98-02 Camaro Grille
    By Chester77 in forum Parts Wanted / Trade
    Last Post: 08-18-2009, 06:38 PM
  2. Grille removal question
    By KIXASS in forum Appearance Section
    Last Post: 08-13-2007, 08:55 AM
  3. Stock Camaro parts, WW grille, Pro 5.0, SLP springs
    By Y2KPewterSS in forum Parts For Sale / Trade
    Last Post: 08-04-2007, 05:56 PM
  4. Grille Removal?
    By bluefields88 in forum Camaro / SS
    Last Post: 07-23-2007, 07:21 PM
  5. Front Grille removal and installation help
    By The Rookie in forum General Help
    Last Post: 11-29-2005, 05:52 AM
