    Member firemedic0135's Avatar
    East Texas
    2000/Trans Am
    Gear swap this week..HELP?
    Ordered 3.73 ring and Pinion for my car Friday and it should be here on tuesday.Anyway I have to get the rearend rebuilt asap as it is Howling terribly and I am afraid it is about to give up the ghost.
    I am going from 2.73 and I already have a license for hptuners so after the swap I can get everything back in order.
    Is the swap something a novice mechanic such as myself handle or should I spend the 2-300 bucks to have a shop rebuild it?
    Anything else I may need to be aware of?
    I have also purchased the axle bearings as I might as well swap them out at the same time.
    Thanks
    John
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    go to how to videos.com and get the one for your rear, that what i did for my 4l60e, i never did a tranny build, but i work at a motorcycle shop and have rebuilt several r6,r1,stx-12f watercraft and many more motors, as long as you can use dial indicators and have experience with bearing race installation you should be able to tackle it, and also make sure every step is done correctly, cause you don't want that rear end locking up on you, not trying to scar you or anything, but watch the video first, and then decide if you have the tools,place,and the ability to perform this swap......best of luck to ya
    Gainesville, VA
    Have a shop do it. Changing rear end gears is not something a novice mechanic should be doing. It's not worth it. Do a search a mechanic on here posted a step by step guide with pics you can judge for yourself after that how feasible it is for you to do it yourself.
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    have a shop due it, and with rears just because you put it in and looks good doenst mean it wont howl, imo rear ends is an art mastered by a few. get it done
  1. Gear swap
    By Al Hazz in forum Drivetrain
    Last Post: 06-25-2008, 08:21 PM
  2. gear swap gains?
    By silverz28camaro in forum GM Trucks
    Last Post: 07-13-2007, 12:02 PM
  3. considering gear swap
    By 02WS6dream in forum Automatic Transmission
    Last Post: 01-06-2007, 04:27 PM
  4. Gear swap
    By Wheeler99WS6 in forum Drivetrain
    Last Post: 11-18-2006, 09:03 PM
  5. 3.73 gear swap
    By mrdavid in forum Manual Transmission
    Last Post: 06-09-2006, 11:16 AM
