Thread: 3.73 gear swap
05-06-2006, 11:18 AM #1see you in my rear view
- Apr 2006
- Boiling Springs SC
Pewter- 2001 WS.6 Trans AM
3.73 gear swap
i have had 3.73 gears for over a year and haven't had them put in yet because i have been getting mixed opinions about them compared to the 3.42 gears. I have had friends tell me there will be slight difference in speed but my drivability will be a lot worse. anyone like to share their opinion. espically someone who has 3.73's ?
05-09-2006, 10:30 AM #2
every post ive seen always recommends going with the 4.10 swap, since with 3.73 the gain isnt that much. I installed 4.10s recently and there is a big difference and the driveability is still fine for me. It's a daily driiver and I still can't complain. Yes there is alot more shifting though. There is no reason why 3.73 would be worse, so I say go for it, but recommend opting for the 4.10s
05-09-2006, 07:23 PM #3
Originally Posted by degenerate
4.10 is the way to go man
05-10-2006, 05:52 AM #4
What is your RPM at when you cruise at 70 with 4.10 gears? around 1900?
05-10-2006, 08:19 AM #5see you in my rear view
- Apr 2006
thanks for the info guys. I got the 3.73's for a steal at $72 so i think i will stick with them for a while, if i desire more take-off i will surely go with the 4.10's. (then some better tires
[B]2K1 WS.6 m6: SLP Lid, MAF, smooth bellows, Y-Pipe, Loudmouth, 160 Stat, TB bypass, TR Velocity Stack, SLP Short Throw, K&N, Taylor 10mm wires w/ iridium NGK plugs, and 255lph F/P, Comp Cam, Chromemoly Rods, Comp Valve Springs
05-10-2006, 04:14 PM #6i have the 16 inch wheel it turn around 18 -1900 rpms but at any time u give it gas you will feel it pull. 1,2,3,4 it will hold u tight in the seat
Originally Posted by 00WS6_TA
05-25-2006, 08:26 AM #7Junior Member
- May 2006
- Lexington
Black- 01 Trans Am WS6
Originally Posted by DJenkin
Can't wait to put mine in!!!
06-09-2006, 10:21 AM #8GM Service Advisor
- Sep 2005
- Los Angeles
Black- 2002 Pontiac T/A Firehawk
I used 3.73's for a couple of years, 'till I messed them up, I liked them...thet seemed "just right".
Now I have 4.10's and I like them better, makes the car a "beast" grappling for traction in 1st and 2nd.2002 T/A Firehawk,M6,Black,IROC Spoiler,Chrome wheels,base suspension and diff.SLP CAI,Y-pipe,SFC,STB,Lightweight steel flywheel,SLP pulley,descreened MAF,B&M Ripper,steel 3/4 shift fork,SLP rear LCA,4:10 gears,T/A girdle with stud kit,HPP3.
06-09-2006, 11:16 AM #9Ratdaddy07Guest
I use the 4.10's in my 6 speed and they are great. supposedly like putting 3.73's in the auto.
Gear swap
By Al Hazz in forum DrivetrainReplies: 8Last Post: 06-25-2008, 08:21 PM -
Gear swap info for all
By RARON455 in forum DrivetrainReplies: 2Last Post: 06-24-2008, 08:55 AM -
Gear swap this week..HELP?
By firemedic0135 in forum DrivetrainReplies: 3Last Post: 08-06-2007, 03:22 PM -
considering gear swap
By 02WS6dream in forum Automatic TransmissionReplies: 16Last Post: 01-06-2007, 04:27 PM -
Gear swap
By Wheeler99WS6 in forum DrivetrainReplies: 4Last Post: 11-18-2006, 09:03 PM
