Results 1 to 3 of 3
Thread: Clutch Problem
08-05-2007, 04:56 PM #1Member
- May 2007
- Fredericksburg, VA
Black- 2001 T/A M6
Clutch Problem
Ok last night my clutch started acting very weird. Then I noticed the pedal got a little lighter and I can could hear the flywheel slapping a bit, then I had trouble getting it in and out of gear and then I thought it was going in reverse period and right as I take off the clutch would grind, thing is it doesn't do it all the time, me and a friend believe its the slave cynlinder which makes a lot of sense because it didn't do it at all today.
I want too know if I should get another factory slave or shop around for a performance one? I believe the factory ones also had a drill mod that you could do to help the slave get more fluid through it to help prevent missing gears at high rpm shifts. Any help, advice, thoughts on this is grateful, thank you.
08-06-2007, 07:07 PM #2Member
- May 2007
Black- 2001 T/A M6
Bump, I really need some info on this by tomorrow if possible. If I got to replace the slave, then I would like an idea of some performance slaves I could buy
08-07-2007, 02:48 PM #3
flush and bleed your system first before tearing your slave off.
another clutch problem
By ali pontiac in forum Manual TransmissionReplies: 2Last Post: 09-29-2010, 02:43 AM -
Clutch problem
By 77k5 in forum DrivetrainReplies: 1Last Post: 05-02-2009, 09:09 PM -
LS7 clutch problem.....
By nmssr08 in forum Manual TransmissionReplies: 14Last Post: 12-16-2008, 04:57 AM -
is it a clutch problem, or a tranny problem?
By sgt0704 in forum Manual TransmissionReplies: 3Last Post: 01-07-2007, 04:03 PM -
Clutch problem..help please
By Scorch in forum Manual TransmissionReplies: 16Last Post: 03-02-2006, 09:34 AM
